Thread: coding a new instrument cluster
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Re: coding a new instrument cluster
    #21
    Near Blackpool
    48 Post(s)
    Also bearing in mind that what ever mileage is on your old car vs donor would also come into it with insurance and MOT wondering why your cars suddenly done a lot less miles. Having never done it I wouldn’t know who to inform to correct this but you will inherit the donors milage.
    You are correct though, VCDS can code all the other options and disable ones you don’t have etc.
  2. Re: coding a new instrument cluster
    #22
    1837 Post(s)
    The donor key idea may work IF you removed the original chip. If you take a used panel to a company with coding gear, they can make it work.
  3. Re: coding a new instrument cluster
    #23
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Tried volkserv in blackpool they won't do it
  4. Re: coding a new instrument cluster
    #24
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Is there any way I can make the key open all the doors , it locks them all but it only opens the driver's door then I have to put the key in the ignition and press the unlock button on the driver's door ???? Pain in the **** !!!!
  5. Re: coding a new instrument cluster
    #25
    Near Blackpool
    48 Post(s)
    VCDS open all button option to on
  6. coding a new instrument cluster
    #26
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by stephenwhite990 View Post
    Strange, my family has used them for about 30 years probably longer so may be more amenable to try things for us.
    If ODIS sees an error like a hardware issue like a rom failure it will come up with a repair procedure for the cluster so will walk you through it. That’s what it did with my ecu issue, we put new one in half way through procedure, it asked what options car had and it coded the second hand ecu to the car. Was quite impressive. Hence why I thought they’d do it for you.
  7. Re: coding a new instrument cluster
    #27
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Quote Originally Posted by jonathanfenton View Post
    Ive looked on vcds which module exactly , I couldnt find it ??
  8. Re: coding a new instrument cluster
    #28
    Near Blackpool
    48 Post(s)
    God this is gonna be a total guess but central connivence long coding?
  9. Re: coding a new instrument cluster
    #29
    Near Blackpool
    48 Post(s)
    Googled it for you and it’s in control module 09 central electrics long coding helper, untick selective central locking active says box 3 but you would need to double check.
  10. Re: coding a new instrument cluster
    #30
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    its not there on mine 07 plate 2.0 tdi its under 46 but it is already unticked???
  1. instrument cluster
    By carcav in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-07-2018, 12:27 PM
  2. New instrument cluster coding.
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-06-2013, 06:42 PM
  3. Instrument cluster
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 05:25 PM
  4. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  5. Instrument Cluster Coding HELP!
    By nisiotis in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2008, 11:18 AM
