Thread: coding a new instrument cluster
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
  1. Re: coding a new instrument cluster
    Near Blackpool
    48 Post(s)
    Because you need the full VAG computer to do it, VCDS which is what most Indi’s have will code a new one but only the VAG one will recode second hand ones. I had same with an ECU, anyone would code a new one but only people with proper VAG computer could code old ones to a different car as it needs to get immobiliser info from VAG database which is obviously not up for sale for RossTech to tap into.
  2. Re: coding a new instrument cluster
    1837 Post(s)
    Even VCDS cannot code in a new one without the SKC or PIN code, the former is no longer available and the PIN has to be extracted using specialist software.
  3. Re: coding a new instrument cluster
    Mar 2009
    Crewe Cheshire
    8 Post(s)
    Looks like im stuffed then , 1700 quid for a new cluster , anyone want to buy an audi a3 which will only open and lock with the key ????
  4. Re: coding a new instrument cluster
    Near Blackpool
    48 Post(s)
    Try Volkservice in Blackpool, even if it’s a long drive it won’t be £1700 in diesel lol
  5. Re: coding a new instrument cluster
    1837 Post(s)
    Any VAG specialist with ODIS and GEKO access can code in a used panel. The dealers can as well but they lie and say they can't.
  6. Re: coding a new instrument cluster
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    What's the set of components that would be needed from a donor car to avoid non-VCDS recoding hassle? Imobiliser in cluster with matching keys, ignition barrel and ECU? Or does it do wider than that?
  7. Re: coding a new instrument cluster
    #17
    1837 Post(s)
    You would need the keys chip, instruments and engine ECU. The chip can be evil to get out without breaking it but the alternative is fitting the lock barrel from the donor car and putting up with mismatching keys which winds me up.
  8. Re: coding a new instrument cluster
    #18
    Near Blackpool
    48 Post(s)
    You’d still need to recode the options the car has as the donor car will likely differ
  9. Re: coding a new instrument cluster
    #19
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Would leaving the donor key that matches the donor cluster on the keyring at ignition be enough, or does it have to be closer?
  10. Re: coding a new instrument cluster
    #20
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Quote Originally Posted by jonathanfenton View Post
    As long as you can do that with VCDS it sounds like a decent route. It's the non-VCDS that seems to be the blocker.
  1. instrument cluster
    By carcav in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-07-2018, 12:27 PM
  2. New instrument cluster coding.
    By Steve_K in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-06-2013, 06:42 PM
  3. Instrument cluster
    By shavermcspud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2011, 05:25 PM
  4. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  5. Instrument Cluster Coding HELP!
    By nisiotis in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-05-2008, 11:18 AM
