Thread: Running problems
  1. Running problems
    Aug 2010
    Redditch
    Hello all
    I've picked up a 2009 2.0 tsi Scirocco with some running issues which has clearly had a lot time and money thrown at it from the previous owner / garage.
    It's very lumpy when running. I will upload a copy of the scan that I carried out today.
    Its had a full set of coils. Cam and crank sensors ( prior to me getting it ) new timing chain which I've checked the timing and all is ok. Compression tested the cylinders. All 160-180 psi.
    Runs 95% when first started from cold but as it warms up becomes lumpy.
    As you can see from the scans it picks up on a cam signal to be faulty.
    Has anyone experienced anything like this ?
    Many thanks
    Ian
    Saturday,04,January,2020,20:43:37:27706
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 19.6.2.0 (x64)
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WVWZZZ13ZAV403863 License Plate: VN09OZR
    Mileage: 144640km-89875mi Repair Order:
    Chassis Type: 13-VW36 (1K0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 37 42 44 46 52 56 77
    VIN: WVWZZZ13ZAV403863 Mileage: 144640km-89875miles
    01-Engine -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
    Part No SW: 06J 906 026 AR HW: 06J 906 026 D
    Component: MED17.5 5271
    Revision: A7H06--- Serial number:
    Coding: 0403000318070160
    Shop #: WSC 00020 067 57207
    VCID: 7AFBFAB035B3639FE9-802E
    3 Faults Found:
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
    P0016 - 000 - Incorrect Correlation
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 144643 km
    Time Indication: 0
    Date: 2014.05.27
    Time: 00:44:01
    Freeze Frame:
    RPM: 1035 /min
    Load: 38.0 %
    Speed: 0.0 km/h
    Temperature: 71.0°C
    Temperature: 31.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 13.970 V
    000290 - Throttle Position Sensor (G69)
    P0122 - 000 - Signal too Low - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 144643 km
    Time Indication: 0
    Date: 2014.05.27
    Time: 00:44:01
    Freeze Frame:
    RPM: 1035 /min
    Load: 38.0 %
    Speed: 0.0 km/h
    Temperature: 71.0°C
    Temperature: 31.0°C
    Voltage: 13.970 V
    000546 - Angle Sensor 2 for Throttle (G188)
    P0222 - 000 - Signal Too Low - MIL ON
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 144643 km
    Time Indication: 0
    Date: 2014.05.27
    Time: 00:44:01
    Freeze Frame:
    RPM: 1035 /min
    Load: 38.0 %
    Speed: 0.0 km/h
    Temperature: 71.0°C
    Temperature: 31.0°C
    Voltage: 13.970 V
    Readiness: 0110 0101
    Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
    Component: ESP MK60EC1 H45 0107
    Revision: 00H45001
    Coding: 763B60F5092200FD6E1306EA901C00813000
    Shop #: WSC 00020 790 00000
    VCID: 7EF3F6A0E99B4FBFD5-802A
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 102
    Mileage: 144643 km
    Time Indication: 0
    Date: 2014.05.27
    Time: 00:25:02
    Freeze Frame:
    Count: 0
    Count: 0
    Count: 13056
    Count: 8193
    Count: 50944
    Count: 256
    Count: 0
    Count: 0
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
    Component: ClimatronicPQ35 133 1213
    Revision: 00133026 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 69D9B5FC4015D80710-803C
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 HW: 5K0 937 086
    Component: BCM PQ35 M 008 0019
    Revision: BC008001
    Coding: 48100A389025E100408800847400012643513B88636D8D605C 8000000000
    VCID: 71E9DD9CA8C520C758-8024
    Subsystem 1 - Part No: 1K8 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 11020 22 0602
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 200509 05 54 0402
    Coding: 0330ED
    Subsystem 3 - Part No: 1K8 951 171
    Component: DWA-Sensor 00 001 0104
    Coding: 000000
    Subsystem 4 - Part No: 1K8 951 605
    Component: LIN BACKUP HO H09 9002
    Coding: 000000
    Subsystem 5 - Part No: 1K8 951 171
    Coding: 000000
    1 Fault Found:
    02395 - Parking Light Front Right (M3)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 102
    Mileage: 144643 km
    Time Indication: 0
    Date: 2014.05.27
    Time: 00:25:06
    Freeze Frame:
    Term 15 On
    Voltage: 13.95 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
    Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
    Component: PARKHILFE 005 1706
    Revision: 00005000 Serial number: 0 263 004 388
    Coding: 100001
    VCID: 3A7B3AB0B533A39FA9-806E
    Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
    Part No SW: 3C0 907 376 A HW: 3C0 907 376
    Component: DAEMPFUNGS-SG H07 0070
    Revision: 00000000 Serial number: 22040900380001
    Coding: 000180
    VCID: 275DF3C456812E77C6-8072
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
    Component: 0H AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 003D1D0169Y.
    Coding: 0012360
    VCID: 6FEDDBE47EF136374E-803A
    Subsystem 1 - Serial number: 6332MSME4735321FB
    Subsystem 2 - Serial number: 6342MSME4401633A3
    Subsystem 3 - Serial number: 6352QSME312D24024
    Subsystem 4 - Serial number: 6362QSME342D4C34N
    Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
    Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
  2. Re: Running problems
    Aug 2010
    Redditch
    Sorry just noticed the cam fault code isn't on that list. Do they have any known issue with throttle bodies?
  3. Re: Running problems
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    The throttle body fault suggests it needs cleaning, if not it may need replacing, check wiring and any fuses too. I had a throttle body issue, mines a TDI, it was full of carbon, once cleaned fault code went automatically after a few drives. It didn't sort any of my issues out however.
  4. Re: Running problems
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Your VCDS scan shows this fault :-
    which to me says there is a timing error somewhere.
    Have a look at this post
    https://forums.ross-tech.com/showthread.php?4812-Audi-Volkswagen-2-0L-Chain-Drive-P0016-Cam-Crank-correlation-check
    I don't know if it is the same engine as yours but may give you some pointers.
  5. Re: Running problems
    1836 Post(s)
    Although incorrect in actual date, the time, date, rpm, road speed etc stamps are all exactly at the same moment suggesting a wiring fault but what was the 40 fault code as your cars build date of 09.06.2009 and engine code CAWB 066632 puts it right in the problem area for chain tensioner failure.
  1. A3 running problems
    By ebo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-06-2009, 08:14 PM
  2. Please Help Running Problems.....Please Help!
    By SIlexDub in forum Golf MK3 - 1993 - 1999
    Last Post: 03-06-2009, 10:49 AM
  3. Running Problems
    By prolag in forum Golf MK3 - 1993 - 1999
    Last Post: 29-09-2008, 07:35 PM
  4. running problems '97 adr 1.8 A4
    By doncornholeio in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-03-2008, 07:01 PM
  5. running problems
    By njb44 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-06-2007, 05:31 PM
