Thread: VW Polo door lock problems
  1. VW Polo door lock problems
    I have a 1999 VW Polo 1.0 L on which the manually operated driver's door lock recently developed a fault. The problem was that the door lock would open on the key, but would not lock. I took the handle assembly out to find that the lock 'paddle' had broken. Not having spares immediately to hand I took the handle assembly from the NS door off in the hope that I could swap over the broken part until I could get a replacement.
    Whilst dismantling the lock assemblies the lock barrels from both handles were removed to be cleaned and greased. However after reassembly I found that turning the key anti-clockwise in the lock would unlock the car but when the key was turned clockwise it would click, the key would not return to the upright position and could not be removed from the lock. The only solution was to remove the door handle assembly and dismantle the lock assembly to remove the key. This procedure was done several times with the same results.
    I have since been told that these door locks have an anti-tamper design which requires a VW special tool to repair and will need to be done at a VW dealer. Is this true or can someone give me some advice?
  2. Re: VW Polo door lock problems
    Aug 2007
    look on ebay there are these kits some dude sell for like £15 or suttin like that... they are for these kinds of problems..... its a way rounf having to visit the dealer n get charged ££££££££ for it ! .. hope this helps!
  1. Door lock problems on MK 4 GT TDI
    By sharky435 in forum New Member Introductions
    Last Post: 29-01-2008, 05:02 PM
  2. A4 door lock problems
    By A4 Driver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2007, 09:26 AM
  3. Polo Door Lock Repaired At Last
    By Paulpro in forum Polo - Derby - Lupo - Fox
    Last Post: 12-09-2007, 01:35 PM
  4. S Reg Polo Door Lock Problem
    By zandy77 in forum Polo - Derby - Lupo - Fox
    Last Post: 16-03-2007, 07:50 PM
  5. Polo door lock
    By westie383 in forum Polo - Derby - Lupo - Fox
    Last Post: 05-08-2006, 09:55 PM
