Thread: Bre engine compatibility
  1. Bre engine compatibility
    Sep 2019
    Hartlepool UK
    2.0 tdi gone to ****.
    This happens christmas eve and only looked at it today.
    Don't know what happened as the missus was driving it.
    From her description sounds like it has ran away on its own oil, took off of its own accord loads of smoke and a few big bangs but due to her supreme knowledge and skills she managed to drive it home🙄
    Anyway it's seized or hydraulic locked.
    Plan on having autopsy when it's out. Replace the turbo if needed so no recurrence.
    Used motors are plentiful but what will need to be done for compatibility? Is it worthwhile getting higher output?
    All roughly the same price
    Does require turbo, ecu or can existing be remapped?
    Tia
  2. Re: Bre engine compatibility
    Sep 2019
    Hartlepool UK
    Ok
    Pulled the cylinder head off today and number 4 rod detached from crank somewhere
    No damage to the head or valves
    Going to pull the motor and have a butcher's
    Will make a decision on repair or replace depending upon what l find and cost of the parts
  3. Re: Bre engine compatibility
    May 2012
    Everywhere
    308 Post(s)
    Bear in mind that the BRE has a flawed oil pump drive and if replacing like for like you must address this otherwise it's just a ticking time bomb .
  4. Re: Bre engine compatibility
    Sep 2019
    Hartlepool UK
    Rain stopped play today doing this on the drive as garage is full.
    Thanks for the pointer and yeah read somewhere about the pump upgrade, the sump has been off at some point white silicone is a bit of a giveaway. With any luck may have been done already.
  5. Re: Bre engine compatibility
    1840 Post(s)
    A small trace of white silicone is factory
  6. Re: Bre engine compatibility
    May 2012
    Everywhere
    308 Post(s)
    Never rely on luck when the inconvenience of a turbo and engine is at risk .
  7. Re: Bre engine compatibility
    Sep 2019
    Hartlepool UK
    Rod snapped holed the block behind oil cooler
    77mm hex drive in the ballance shaft, was on its way out by the looks of things
    I will post a few pics up when I get to desktop.
    So engine is 108 what needs to be done if I put a higher output in.
    Looking around for a new motor, higher output seem to be more available with better choice of milage etc.
  1. Engine swap compatibility
    By Whybother? in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-06-2018, 07:06 AM
  2. Engine Compatibility A3 ahf
    By Jack310160 in forum 1.9TDi - Engine
    Last Post: 16-01-2013, 04:38 PM
  3. AYM Engine compatibility with AFB
    By cs.wenderby in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-01-2013, 12:20 PM
  4. Engine compatibility codes ?
    By yamman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-03-2012, 02:02 PM
  5. 2.5 TDi engine compatibility
    By BoyceyS4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-10-2011, 08:18 PM
