Thread: audi a1 2.0 tdi 2013 fuel pump injector coding
  1. audi a1 2.0 tdi 2013 engine change & fuel pump injector coding
    Feb 2010
    North east UK
    hi all, having thrown a rod after turbo failure on a cfh engine, I'm replacing the engine including turbo fuel pump and injectors. the question I have is are the fuel pump and injectors coded to the ECU on this model. if so I'll swap them from the wrecked engine before firing up.
    also is there room to split engine from gearbox in situ as this will be easier then removing both as a unit then splitting.
    thanks
  2. Re: audi a1 2.0 tdi 2013 fuel pump injector coding
    Feb 2010
    North east UK
  1. Audi A4 2.5TDi fuel pump coding
    By lastyboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2023, 07:10 PM
  2. Question fuel injector pump
    By looert in forum Touran - Sharan - Caravelle
    Last Post: 01-04-2010, 02:43 PM
  3. Question 94-TDI Fuel leak around injector pump?
    By Timk in forum 80 - 90
    Last Post: 03-08-2009, 06:30 PM
  4. Question Fuel pump injector problem
    By dan_r in forum Audi A3 - Archive Topics
    Last Post: 06-10-2008, 11:24 AM
