Thread: Turbo hose problems
Results 1 to 9 of 9
  1. Turbo hose problems
    Mar 2013
    Northern Ireland
    Hello everyone, some advice would be appreciated. My Passat has started to hunt when driving. Also have noticed smoke from rear and also loud noise when accelerating ( like a loud sucking air noise ). Would this be the start of the turbo going. I have just noticed the hose from the air out of the turbo has about an inch split in it. Obviously this wouldnt help the car but would it be part of the problem and if so could it have damaged the turbo.
  2. Re: Turbo hose problems
    May 2012
    Everywhere
    308 Post(s)
    Engine code ?
  3. Re: Turbo hose problems
    Mar 2013
    Northern Ireland
    Don't have engine code
  4. Re: Turbo hose problems
    1837 Post(s)
    AVB, AWX, AWF, the engine type code. Yes that pipe splitting is a standard problem. Guessing at a 2003 AWX, the hose is VAG part number 3B0 145 828 G but are a daft £146.50, as it is such a common failure they are easy to buy aftermarket for a fraction of that.
  5. Re: Turbo hose problems
    Mar 2013
    Northern Ireland
    Cheers Crasher. It's a 2004 passat. Would that split actually cause those problems or similar?
  6. Re: Turbo hose problems
    1837 Post(s)
    Very much so, when it splits they pump black smoke, even a tiny air leak causes problems.
  7. Re: Turbo hose problems
    May 2012
    Everywhere
    308 Post(s)
    Then there's the poor joints and the vnt overboost limp mode to look forward to .
  8. Re: Turbo hose problems
    Mar 2013
    Northern Ireland
    Cheers, will replace and see how it goes.
  9. Re: Turbo hose problems
    Mar 2013
    Northern Ireland
    Replaced hose. Now going like a dream.
    Cheers everybody
  1. Turbo hose damage
    By dazza12 in forum Touran - Sharan - Caravelle
    Last Post: 14-01-2016, 02:56 PM
  2. Question T5 Turbo hose blowing off
    By Aldicko in forum The Commercial Range
    Last Post: 23-07-2010, 09:29 PM
  3. Split Turbo Hose
    By pass&golf_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2010, 08:31 PM
  4. Question Cheap Turbo Hose kit
    By richie_jones in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-11-2008, 07:35 PM
  5. turbo hose
    By rubezz in forum Chat - Anything with wheels
    Last Post: 07-07-2008, 03:20 PM
