Thread: Which coolant pump?
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. Re: Which coolant pump?
    #21
    Jun 2020
    Ireland
    No, it's not under load - around 50-60 mph. Or could it be thermostat or temperature sensor? I will have to connect dongle again and check how it works while driving is it only on dash or is it for real.
    Head gasket is rather impossible as engine was never overheated or so, plus low millage.
    Small update pump 3 error is back from yesterday. So it looks like it's time to contact VW and ask what pump do i have or visit garage and ask them to check.
  2. Re: Which coolant pump?
    #22
    Jun 2020
    Ireland
    So i was able to check today and in front of the engine(under oil filter) i have bosch 0392023209 5G0965567(no letter at the and) but etka is showing me a new part number 2Q0965567A - which Bosch water pump is it? 0392023421 or 0 392 023 454 or 0 392 023 455?Or is it important at all which bosch number is it - maybe it is better to look at vw number and manufacture year?
  3. Re: Which coolant pump?
    #23
    1837 Post(s)
    I get the coolant support pump as being 5G0 965 567
    yes, VAG number 5G0965567
  4. Re: Which coolant pump?
    #24
    1837 Post(s)
    I have just checked now at work and it supersedes to VAG number 2Q0 965 567 A which is £95.83 and a Bosch 0 392 023 454
    http://emea.resource.bosch.com/AA/in...000/index.html
  5. Re: Which coolant pump?
    #25
    Jun 2020
    Ireland
    That's what i needed . Big thank you - i will visit skoda dealer today as they were always cheaper then VW
    @Crasher that price is with VAT or plus VAT? OK, now I see with VAT.
  6. Re: Which coolant pump?
    #26
    1837 Post(s)
    The genuine retail price is the same for the same part number at whichever of the five VAG dealers you would get this from. If you are not using TPS, you are advised to buy the part from the dealer responsible for the brand as this would make any subsequent warranty much easier.
  7. Re: Which coolant pump?
    #27
    Jun 2020
    Ireland
    Sadly true - same price at skoda and vw. 103€ down here.
  8. Re: Which coolant pump?
    #28
    Oct 2020
    Ukraine
    Hello loki7777, my car is showing code P26F8 (Volkswagen passat b8 2.0 tdi 2017). Its pump 3, but I don’t know what part number. Could you advice please.
  9. Re: Which coolant pump?
    #29
    Jan 2008
    Hey chaps
    Getting the same fault code as OP
    28253 - Coolant Pump 3 P26F8 00 [032] - Stuck
    Engine DGCA 2018 Golf 2.0 TDI
    What was the resolution to fix the code?
    Was it replacing the electrical pump (which one front v188 or back v488) or the timing belt pump
    TIA
  10. Re: Which coolant pump?
    #30
    Nov 2022
    Bristol UK
    Quote Originally Posted by N871BUD View Post
    Hello, had a intermitent issue for a while but now is more and more often, and pending even with MIL off
    Engine code: EA288 CRLB 2.0 TDI 110kw 150 HP
    1 Fault Found:
    P26F8 00 [175] - Stuck
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 172300 km
    Date: 2019.12.30
    Time: 08:33:05
    I am suspecting is one of the electrical coolant pumps, but which one? the one for the charge air cooling inlet manifold or the one for the auxiliary heating one. And yes are 3 water pumps... in total.
    Not sure which one to get the bosch one or pierburg one? anyone knows which puts up this code?
    Can i ask if these engines are any good, an issues with them like oil pump failure or anything else as i am thinking of buying this car next couple of days thanks, sorry for off topic, but desperate for advice thanks
  1. Coolant pump B open cct P261A 00(237)
    By dovski in forum VCDS - Help Requests
    Last Post: 15-01-2019, 01:55 PM
  2. Question P261A – Coolant Pump 2 issue (pump failure), need advice.
    By jkeeeng in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 10:28 PM
  3. P261A error code - auxillary coolant pump B - where is this pump?
    By 3rdpassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2015, 08:31 PM
  4. Coolant Pump Failure (or something more serious?)
    By Degsy in forum Golf MK4 - 1999 - 2004
    Last Post: 16-10-2011, 08:47 AM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
