Thread: 2.0 tdi filter change - help!
Results 1 to 10 of 12
  1. 2.0 tdi filter change - help!
    Feb 2017
    11 Post(s)
    I've just drained the oil, took the old filter out and went to fit the new one, but the filter I was supplied has a ~1 inch "rod" on the end, and the filter I removed hasn't. The YouTube videos I watched showed the same filters with no issues, but the new filter won't fit in as there's already a "rod" in the filter housing. Have I been given the wrong filter or have I done something wrong?!
  2. Re: 2.0 tdi filter change - help!
    Sep 2015
    Leics
    11 Post(s)
    Sounds like the old ‘rod’ has snapped off. I vaguely recall lubricating 2 o-rings when I changed mine so it definitely had a rod with a small seal near the bottom.
  3. Re: 2.0 tdi filter change - help!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Mine always have the "rod". It doesn't fasten in the housing very tightly - I expect you'll be able to turn it easily in there if it is snapped / loose, and pull out with long nosed pliers or similar.
    Just in case it's different, what engine code is on the service book or door pillar sticker? BKD, AZV, etc.
  4. Re: 2.0 tdi filter change - help!
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by Nedski View Post
    There are 2 types of filter listed for B6 Passats, one with the rod, the other without. You should be able to tell whether the rod snapped off or not, and if not you need the other filter type.
    Mad Mitch
  5. Re: 2.0 tdi filter change - help!
    Feb 2017
    11 Post(s)
    Brilliant, thanks! Euro Car Parts only lists one filter which I thought was safe to assume it would be correct!
  6. Re: 2.0 tdi filter change - help!
    Jan 2012
    10 Post(s)
    87 Post(s)
    The PD engines predominantly have the extended rod and seal. The plain filter insert is normally found on some Common Rail engines e.g. CFFB. Always make sure the right one is fitted.
    Mad Mitch
  7. Re: 2.0 tdi filter change - help!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    What engine code do you have?
  8. Re: 2.0 tdi filter change - help!
    Feb 2017
    11 Post(s)
    Quote Originally Posted by vag-abound View Post
    what engine code do you have?
    cbab
  9. Re: 2.0 tdi filter change - help!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    cbab
    As far as I can see CBAB uses filter part 071115562C, with rod. The other type 03L115562 with no rod (and hole through middle) is used on Passats after 2009. Search for them on eBay to compare.
  10. Re: 2.0 tdi filter change - help!
    Jan 2012
    10 Post(s)
    87 Post(s)
    Mad Mitch
  1. Anyone know how to change the air filter?
    By surfdub in forum Q7 - 4M Forum - 2016 -
    Last Post: 03-04-2019, 08:02 PM
  2. Air filter and cabin filter change on Touran 1.6Fsi.
    By driver2008 in forum Touran - Sharan - Caravelle
    Last Post: 29-12-2014, 11:09 PM
  3. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  4. How To B8 TDI oil Filter change
    By Boy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-09-2013, 09:55 PM
  5. How to change CVT filter? DIY possible?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-11-2008, 01:47 AM
