Thread: which fuse???
  1. which fuse???
    Jun 2006
    Hi i was wondering if anyone could help me......the lights that appear when you turn the main beams on by the heater controls (like warm, cold, where you want the heat to go ....on your face , by ur feet etc) those dont light up was wondering if any1 knew what fuse i need to change, iv got the pictures on a card by the fuse box however cant figure out which one it is out of the millions ther!
    i have a vw golf mk4
    any help would be gr8!
    cheers
    cookie_monster
  2. panel lights
    Aug 2006
    Berks,Hamps, Surrey corner
    Hi there, the laights you talk about work off the same fuse as the nstrument panel. If that's working then it's probably the bulbs which have failed, quite common. Regards, phil
    Jun 2006
    mite sound a bit stoopid.....but wots the instrument panel? ....and will it cost much to get new bulbs put in if it is that? thnx in advance phil
    Aug 2006
    instrument panel is the lump in front of you with a speedometer and fuel guage. changing light bulbs in heater display controls can only be done with heater control panel removed from dashboard, not expensive.
    Jun 2006
    hey, thats kool then, your help was much appreciated phil!
    regard
    cookie_monster
  6. Lightbulb Re: which fuse???
    May 2007
    Any one got any tips on how to get to the bulbs on the panel as I have undone nearly everything around it and still could not get to them!??
  7. Talking Re: which fuse???
    May 2007
    Found out how to do it undo the middle nob and the bulb is right there RESULT!
  1. Touran fuse box
    By nickatwharf in forum Touran - Sharan - Caravelle
    Last Post: 11-03-2008, 09:01 PM
  2. Fuse for stereo
    By frankieboy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-06-2007, 01:13 AM
  3. How much can the fuse box take?
    By jabba2020 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 08:14 PM
  4. fuse box
    By vwgolfse in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-03-2007, 03:41 PM
  5. Fuse box
    By M4YTY in forum Passat - Archive Topics
    Last Post: 02-03-2007, 11:37 PM
