Thread: Rear door exterior handle
  1. Rear door exterior handle
    Sep 2015
    Leics
    The rear door handle will not open the door when unlocked. The door still opens from the inside so does that mean the cable hasnít snapped? Has anybody had this problem, if so what was the fix? The handle also pulls out without much resistance if that helps. Any help would be greatly appreciated.
  2. Re: Rear door exterior handle
    Jan 2012
    Rustington, West Sussex UK
    6 Post(s)
    64 Post(s)
    Quote Originally Posted by LiamP1985 View Post
    The rear door handle will not open the door when unlocked. The door still opens from the inside so does that mean the cable hasn’t snapped? Has anybody had this problem, if so what was the fix? The handle also pulls out without much resistance if that helps. Any help would be greatly appreciated.
    If I recall correctly there are 2 cables or one long one and one short swing piece and often the short one comes off or breaks. Unless you can get the handle to re-engage the short cable / swing piece end, if not broken, as many have in the past (search the forum), then it will have to be dismantling time.
    Mad Mitch
  3. Re: Rear door exterior handle
    Sep 2015
    Leics
    Thankfully got it working after seeing a video on YouTube which involves turning the yellow screw on the side of the door card. Donít know how it worked, but it did.
  1. Passenger door occasionally not opening with the exterior door handle
    By poosnip in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-03-2017, 02:08 PM
  2. Exterior Door Handle LED Lighting
    By Lewis-Oddie in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-03-2016, 08:35 PM
  3. Help D3 exterior door handle replacement
    By instrutec in forum A8 - S8 - V8
    Last Post: 21-05-2011, 06:28 PM
  4. Question Exterior door handle lights
    By Hardcorism in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-02-2011, 05:49 PM
  5. Question Passat Exterior Door Handle
    By richiekeys123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-02-2010, 08:23 PM
