Thread: 2008 A3 Brake Pad Wear Sensor Location?
  1. 2008 A3 Brake Pad Wear Sensor Location?
    Hi excuse the dumb question but had the brake pad wear light come on so thought it would be a simple front pad change. However on checking I can't see any sensor on the front pads? I expected to see it coming off the inside pad but there is nothing an no wiring harness - only the ABS sensor and wiring the other side. I've searched the internet but no joy. Is there anything on the rear?
    The car is a 2009 A3 2.0 TDI 3 Door Hatchback.
    Any advice gratefully received.
  2. Re: 2008 A3 Brake Pad Wear Sensor Location?
    Near Blackpool
    48 Post(s)
    Mines on near side I think on inner pad? Unless someone’s shorted it out and the wire bridge has failed but the loom is attached the to the strut and then splits off one for abs and one for pad wear
  3. Re: 2008 A3 Brake Pad Wear Sensor Location?
    Thanks - just found it when I took of the NSF!!!
  1. Brake wear sensor
    By Panzerdriver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2012, 09:33 PM
  2. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  3. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  4. Brake Pad Wear Warning Light 2008 TDI Sharan
    By blue70 in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2011, 10:36 AM
  5. Brake wear sensor
    By kennym999 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-01-2010, 10:52 PM
