Thread: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
Results 1 to 9 of 9
  1. 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Dec 2019
    Hello,
    Got a 2015 1.4 110kw gas 6 speed manual, 99k km on the odo and I love it, apart from a couple problems:
    1st problem:
    The clutch, when it is cold feels very 'grabby'.
    Grabby = just before motor speed and gearbox speeds match, the clutch just grabs and pulls the car forwards, without moving clutch pedal.
    Main problem is the car would start jerking if I would try to start moving faster in 1st gear.
    It feels like, the clutch would grab, compress the cushions/mounts (don't know how they're called in english) of the gearbox/motor and then it would get loose, and then it would grab again...
    Just heat the clutch a bit and the problem is gone... This is strange.
    I guess its mainly worn out/overheated clutch with bent plates or whatever and I am planning to replace it, no problems with that.
    All engine/gearbox mounts seems good, inspected at the service.
    2nd problem:
    The worst thing - sometimes, and only sometimes it is hard to get the reverse gear in. It doesn't grind or anything, it goes half way and it is hard to get the last step (too hard)... Didn't try it without car off...
    Most of the time its efortless.
    Could it be that some of the gear teeth are bad ? Should I inspect/rebuild the gearbox together with clutch change ? Or could it be just a linkage missalingment or something like that ?
    Does the reverse have syncros or something like that ?
    Any opinions and ideas are welcome, glad to join this forum.
  2. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    1840 Post(s)
    I think you will find a new clutch and DMF deals with both issues.
  3. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Mar 2013
    Brightlingsea
    8 Post(s)
    I agree with Crasher. I believe that earlier Passats than yours had a recall due to a DMF issue? If you Google vw dual mass flywheel you will find lots of info, including videos where you can hear the symptoms.
  4. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Nov 2017
    Cambridgeshire
    10 Post(s)
    Will a 1.4 petrol have a DMF?
    I can’t imagine it would
    2015 Passat B8 2.0TDi 150 GT Estate in Deep Black
    2005 A2 1.4TDi 75 SE in Silver
  5. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Mar 2013
    Brightlingsea
    8 Post(s)
    You can buy one: Flywheel for VW Passat B8 Variant (3G5, CB5) 1.4 TSI (150 HP from 2014 ). Whether that means they were all fitted with one I don't know.
    EDIT: that link says it's for a DSG, so maybe the manual doesn't have one.
  6. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Nov 2017
    Cambridgeshire
    10 Post(s)
    That site just keeps coming back to braking and suspension parts, can’t find any mention of a flywheel never mind a dual mass flywheel!
  7. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Mar 2013
    Brightlingsea
    8 Post(s)
    When I click the link I posted I get this page:
    Ah but... then I see it's for a DSG, so maybe the manual doesn't have a DMF.
  8. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    Nov 2017
    Cambridgeshire
    10 Post(s)
    It doesn’t open that page for me, but as you say that refers to DSG - perhaps Dual Clutch gearboxes need a DMF for some reason but I doubt the manual requires one
  9. Re: 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    1840 Post(s)
    IT depends on the engine code, a front wheel drive type type 3C with a CZEA engine has a DMF under part number 04E 105 266 H but if it is a CZDA it is solid.
  1. Problems selecting reverse (6speed manual)
    By unkateef in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-09-2017, 03:07 PM
  2. GT TDI 4MOTION, Clutch, gear selecting reverse and 1st.
    By Jack Bishop in forum Golf MK5 - 2004 - 2009
    Last Post: 26-05-2015, 12:59 PM
  3. Gear Shifting Problems
    By Gebraffe in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2010, 01:52 PM
  4. Reverse gear problems
    By bluehuggydog in forum Golf MK3 - 1993 - 1999
    Last Post: 25-02-2009, 10:35 AM
  5. No more reverse gear after new clutch install
    By ATC Salty in forum Golf MK2 - 1984 - 1992
    Last Post: 23-07-2008, 12:28 AM
