Thread: Need help, don’t wanna loose the car
Results 1 to 10 of 18
  1. Need help, don’t wanna loose the car
    Dec 2019
    Wales
    Ok so I was driving normally, and then my car started loosing power so I changed to a lower gear and after a couple minutes my battery light come on, my steering got heavy and my car cut out, when I went to start the car for some reason my starter motor wouldn’t engage, after I got the car home I checked my cam belt and when I looked at it there was 4 or 5 teeth missing, I won’t wanna put money into buying a new starter motor and changing the cam belt/ water pump etc... so could anyone help me and give me some options on what to do, I really don’t wanna loose this car or spend too much money on the car, thanks
  2. Re: Need help, don’t wanna loose the car
    Near Blackpool
    48 Post(s)
    Fix it or scrap it???? Not sure what answers you’re hoping to gain from here?
  3. Re: Need help, don’t wanna loose the car
    Dec 2019
    Wales
    Quote Originally Posted by jonathanfenton View Post
    I wanna know if the timing is out if not then if it’s worth fixing
  4. Re: Need help, don’t wanna loose the car
    Near Blackpool
    48 Post(s)
    That would require rotating engine and checking cam timing marks.
    1 1 0
  5. Re: Need help, don’t wanna loose the car
    Dec 2019
    Wales
    If the marks don’t line up it’s out of timing?
  6. Re: Need help, don’t wanna loose the car
    Near Blackpool
    48 Post(s)
    Correct and you’ll probably have some bent valves
  7. Re: Need help, don’t wanna loose the car
    Dec 2019
    Wales
    Ok cheers, thank you for your help
  8. Re: Need help, don’t wanna loose the car
    May 2012
    Everywhere
    308 Post(s)
    When was the cambelt ( w/pump kit ) last done ?
  9. Re: Need help, don’t wanna loose the car
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    It might help if you told us what engine is in the car.
    If it's a diesel, you could be looking at a mega bill, if a petrol you might be more lucky.
    Bear in mind it is at least 15 years old (going by you posting in the MK 4 Golf pages), so it's probably not worth spending a fortune on it.
    0 2 0
  10. Need help, don’t wanna loose the car
    Dec 2019
    Wales
    Quote Originally Posted by Alan G H View Post
    It’s a 1.6 petrol
  1. I wanna get off the wheel!
    By gupsterg in forum Chat - Completely Off Topic
    Last Post: 24-10-2014, 10:53 AM
  2. Replies: 21
    Last Post: 24-10-2013, 07:46 PM
  3. I Wanna Say This
    By DSG4ME in forum Chat - Completely Off Topic
    Last Post: 17-04-2013, 04:23 PM
  4. Just wanna say hello
    By Driver RX in forum New Member Introductions
    Last Post: 10-06-2012, 04:04 PM
  5. wanna map my engine
    By 5up3rman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2010, 08:29 PM
