Thread: Driver’s door will not open from outside
  1. Driver’s door will not open from outside
    Sep 2012
    Stourbridge
    Car is unlocked but the driver’s door can only be opened from inside. What's more, the outside handle does feel a bit looser ie does not have as much resistance as normal. Is this likely to be a broken or unclipped cable or does this handle not work this way. Is it likely to be a big job to fix?
    thanks
    the car is 2012 avant a6
  2. Re: Driver’s door will not open from outside
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    I had this a few weeks ago, mine is a 2012 but under warranty, took it to audi where it decided to work perfectly and has been fine since.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Driver’s door will not open from outside
    Nov 2018
    Liverpool
    Iv had this on my 13 plate, i just had to lock and unlock a few times, or if that failed take the key out the fob and open manually
  4. Re: Driver’s door will not open from outside
    Sep 2012
    Stourbridge
    I’ve tried this with no success. I spoke with an audi specialist garage who said this is a very common problem and requires a replacement lock, which in now modified, and a new cable. Cost approx £250 and can do it on Monday (today is Friday). They have also done an A5 this week. Guess this might be an Audi part problem on some models. Not too impressed as car only done £15k miles. Will let you know more after door is stripped down.
  5. Re: Driver’s door will not open from outside
    Apr 2020
    Nottinghamshire
    I had this on a 2012 Allroad on both passinger and drivers door. The drivers went first then passinger a year later. Replaced both door latches myself and got the parts from Motors-in-Motion whos are specialist VAG breakers. It was a couple of years ago but think parts were less than £40 delivered. Once door card is off and you work out how to get handles off its easy. All tips are on youtube.
  1. Driver door handle wont open door broken ....pulley rod....help !
    By Sam James in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2019, 01:10 PM
  2. Cannot open driver door at all
    By Leckie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2015, 05:50 PM
  3. HELP!!! Driver door won't open.
    By dbooker89 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2014, 01:21 PM
  4. Driver door won't open
    By joeyjoejoe in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-02-2010, 09:47 PM
  5. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
