Thread: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
  1. Exclamation SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    Aug 2013
    Felixstowe
    Hi folks,
    Having an issue with my immobiliser (or something related).
    Getting the "SAFE" warning on dash and the glow plug light is flashing.
    This happened a few days ago while out shopping with no tools, so had the AA out and after a few failed attempts at disconnecting and leaving the battery and the long winded process of leaving the key in the ignition for 15 mins etc, eventually managed to get it going again by removing the clocks and plugging them back in. The car was fine for a few days after this.
    Unfortunately it wasn't a one off, and it happened again today. Didn't have time to trouble shoot further as i was late for work. I've read it could be a multitude of things from relay, fuse, coil pick up in dash etc.
    Would appreciate some help to diagnose.
  2. Re: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    108 Post(s)
    1816 Post(s)
    You need a full car fault code read to see what is going on.
  3. Re: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    Aug 2013
    Felixstowe
    When it was scanned by the AA, it was just the Immobiliser code - which one i can't tell you. I will scan it later and report back.
    Pulling the speedo and plugging it back in rectified the issue
  4. Re: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    Aug 2013
    Felixstowe
    Quote Originally Posted by mgsmagsmags View Post
    Well I’ve just come back to it and it’s fine. No stored codes. Annoying as I want to diagnose it not leave it to happen again. Will report back if and when it happens - in the mean time if anyone would care to help me do any preventative checks etc that would be grand
  5. Re: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    Aug 2013
    Felixstowe
    seems to be an intermittent issue. Happened again today. Pulled the key out of the ignition, turned it on again and it was absolutely fine.
  6. Re: SAFE Warning car won't start immobiliser issue - A3 2005 2.0 TDI BKD
    108 Post(s)
    1816 Post(s)
    Most likely the reader coil on the barrel.
  1. Please Help Flooded! AIRBAG warning light, Flooded interior, multiple warning lights AND Tiptronic safe mode
    By jules n in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-01-2016, 05:56 PM
  2. Immobiliser safe?
    By Troyboy9061 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2015, 06:56 PM
  3. 2005 B7 2.0TDI: Brake warning light on start up
    By Marty 55 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-09-2014, 09:16 PM
  4. Question Audi A4 2005 Immobiliser Issue?
    By Jik in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2011, 09:57 PM
