Thread: Golf MK5 GT TDI (140) Turns over but wont start
Results 1 to 10 of 13
  1. Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2019
    huddersfield
    Hello,
    New to this site, I own a 2007 MK5 GT TDI (140). For a while It sometimes turns over for 2/3 seconds then starts, sometimes starts straight away. Yesterday it would not start at all but would just keep turning over. i managed to get a push and get it started and it has been starting fine since as well as this morning (still at times turns over for a few seconds then starts).
    I took it to the garage yesterday, it was showing codes for glow plugs and showing 'camshaft' with no signal/response
    any idea what it could be?
    Zak
  2. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2014
    Bedford
    42 Post(s)
    Cam sensor?
    Sent from my SM-G970F using Tapatalk
  3. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2019
    huddersfield
    Yes Camsensor shows up on computer as no response/signal
    Zak
  4. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2019
    huddersfield
    Not sure if a faulty cam sensor could cause starting isssues?
    Zak
  5. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2014
    Bedford
    42 Post(s)
    If cam sensor is faulty it will use crank instead, but consequently it will turn over for longer.
  6. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2019
    huddersfield
    Ah okay Thank you , so cam sensor could have caused the problem i had yesterday when it would just turn over for ages but not start? I have also noticed poor performance upon accelerating, power is not there as it use to be
    sorry but i know minimal on the cam sensor and crank, but think I will get the cam sensor replaced
    Zak
  7. Re: Golf MK5 GT TDI (140) Turns over but wont start
    108 Post(s)
    1816 Post(s)
    You could have three or four issues stacking up here, glow plugs are vital in this weather, we had a Tourag 5 cylinder in last week with terrible starting, all five were burnt out and a new set cured it. Also the cranking rpm can be too low, you check this by disconnecting the head harness and then cranking the engine over whilst using a diagnostic system to view the speed, it must be a minimum of 280rpm. If you had four faulty glow plugs, a slow cranking starter and a failed G40 cam position sensor then it could easily add up to your problem.
  8. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2014
    Bedford
    42 Post(s)
    I reccomend changing your glow plugs before there gone, I just snapped my first one ever in 27 year's. No4 on a Porsche Cayenne, same engine as Touareg v6 Tdi. Oh dear never mind at least I can kind of get a drill in there.
  9. Re: Golf MK5 GT TDI (140) Turns over but wont start
    108 Post(s)
    1816 Post(s)
    The CR TDI V6 is a sketch, when we do them at least on snaps and it is not uncommon for all six to snap... hate them.
  10. Re: Golf MK5 GT TDI (140) Turns over but wont start
    Dec 2014
    Bedford
    42 Post(s)
    Well I won that battle.
    1 1 0
  1. Question T4 1998 2.5tdi Manual - Will Not Start - Turns but wont run
    By Patrickk in forum The Commercial Range
    Last Post: 04-07-2017, 06:30 PM
  2. Turns over but wont start
    By Biggzy Knight in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-07-2017, 12:51 PM
  3. 99 tdi no dash lights turns over wont start
    By pg339 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2013, 04:07 PM
  4. car turns-over but wont start ?
    By v8slugger in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2010, 03:39 PM
  5. Car turns over but wont start...
    By kjopen in forum Golf MK3 - 1993 - 1999
    Last Post: 08-03-2008, 04:06 AM
