Thread: How to test an exhaust gas tempoerature sensor?
Results 1 to 10 of 13
  1. How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    Long story this, it follows from previous woes of sensors, DPF etc. The 2.0 tdi 170 quattro got sorted by cleaning DPF and replacing the temperature sensor one eventually, it came out of limp mode and all lights off. Plus cleaning a stuck EGR etc etc. It drove for 1000 miles or so fine.
    Then the glow plug and MIL light come on again, my scan indicates again the temperature sensor one, bank one. This was replaced just after buying the car two years ago and again very recently.
    It may be a duff sensor? wiring looks ok.
    does anybody have an checks i can make for resistance values cold and as it warms up using a multimeter?
    It is a swine to change and I do not want to swap it again if it is testing ok as a sensor and the issue is elsewhere on the loom/ecu.
    Thanks for any help.
  2. Re: How to test an exhaust gas tempoerature sensor?
    1836 Post(s)
    The BMM engine can be very trying, first of all, is the MAP standard?
  3. Re: How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    Yes it has been trying in our 2 year ownership.......one of the worst cars we have ever had and its lowest mileage we bought for a long time too! from recollection its a CBBB code engine and as far as I know it is all bog standard. One previous owner with all its records prior to us.
  4. Re: How to test an exhaust gas tempoerature sensor?
    1836 Post(s)
    The CBBB is usually OK, the previous BMN was an awful engine, which year is it?
  5. Re: How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    Hi Crasher, thanks as always.....first reg. December 2008, CBB engine number on log book though CBBB is on the sticker in the service book. The code wont clear and stay out at all, so I wonder whether to simply invest in another temp sensor and plug it in out the car cold then see what happens on a start up/fault clear etc. DPF light not back and it runs fine...for now
    Its another £50-60 but less than losing it to a garage straight away.
    My scanner is VW/audi but not a full vag-com.
  6. Re: How to test an exhaust gas tempoerature sensor?
    1836 Post(s)
    It will be a 2009 model, which EGT sensor is at fault, 1, 3 or 4?
  7. Re: How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    EGT Sensor 1 bank 1. so I believe it to be the one tucked under the DPF/Cat area which I changed and sorted it for a bit! That was done on warranty just after buying it and that was what started issues again before hte DPF/limp mode fiasco! I changed it and that code cleared then we did the DPF clean to get it out limp mode and the DPF light off.
    As said it drove no lights for 1000 miles or so, now again the glow plug light blinking and MIL light, scans as temp sensor 1 bank 1 again.
    I do confess perhaps the sensor was of dubious quality! we were throwing things at it and it did prove the fault as the code cleared however maybe it has failed early.
    Oh fogot to add it also had a new pressure snesor switch on the DPF seeing as it was giving bizaar readings out of spec. That is good quality!
  8. Re: How to test an exhaust gas tempoerature sensor?
    Dec 2014
    Bedford
    42 Post(s)
    What you need to look at is live readings of all exhaust gas temperature sensors, when the engine is cold and not been started. All should be about the same any anomalies in temperature and thats your problem. Then once that is sorted and faults are erased make sure your dpf offset value is zero. Then a forced regeneration.
    Sent from my SM-G970F using Tapatalk
    1 1 0
  9. Re: How to test an exhaust gas tempoerature sensor?
    1836 Post(s)
    The CBBB EGT 1 is in the manifold
    CBBB EGT system
    1) Turbocharger
    2) Control pipe
    3) Particulate filter
    4) Nut
    5) Bracket bolted to particulate filter
    6) Hose
    7) Bracket for exhaust gas pressure sensor G450
    8) Exhaust gas pressure sensor G450
    9) Bracket
    10) Bolt
    11) Bolt
    12) Exhaust gas temperature sender 3 G495
    13) Lambda probe G39 with Lambda probe heater Z19
    14) Exhaust gas temperature sender 4 G648
    15) Exhaust gas temperature sender 1 G235
  10. Re: How to test an exhaust gas tempoerature sensor?
    Dec 2014
    Bedford
    42 Post(s)
    And if you replace no1 egt make sure the long metal tip is not touching any part of the turbocharger when you tighten it up, as you will get false readings.
    1 1 0
  1. How to test coolant sensor loom for 5v?
    By TdiBlacky140 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-11-2019, 12:08 AM
  2. Question Engine speed sensor test G28
    By trickyd400 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-06-2019, 12:24 PM
  3. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  4. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  5. oxygen sensor aging test for sensor 1
    By mkman1 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2014, 04:52 PM
