Thread: How to test an exhaust gas tempoerature sensor?
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    I have updated the latest tale of woe on the other thread......I sorted it by replacing EGT 1 again BUT not for long! Driving me mad...ideas welcome, but think i need to try another sensor make???
  2. Re: How to test an exhaust gas tempoerature sensor?
    1837 Post(s)
    Give us a current fault code report, the make and part number of sensor and where you fitted it.
  3. Re: How to test an exhaust gas tempoerature sensor?
    Jun 2012
    Surrey
    Hi Crasher, Thank you, if you were local I would say hello one day you are more than helpful and it is appreciated.
    Current code is simply 01348 can bus interior monitor lamp (K162) sometimes it throws up G235 but not currently.
    The part is of dubious source but I have used their parts before on my other Audi cars fine. part number is 03L906088BS make unknown THH?
    It looks correct and is the black plug. sensor 1 bank 1.
    Fitted twice now in that awful place under everything where it is not really possible to even fit a spanner...manifold before turbo....grazed arms and chest from laying on the engine haha.
    The 2nd was supplied on warranty. Both times I could unplug the harness plug the new sensor in (though not fitted) and clear the fault code, start it run it no fault lights with new sensor plugged in not installed. If I plug the suspect fitted one back in the fault light is immediate...clear it and it comes back on in seconds. This all seems to point to the sensor either failing in a few hundred miles or it not being a good match?
    After fitting the 2nd one I drove it for about 20 miles to regen. and cleared the DPF light......all seemed good, 400 miles later the glow plug light and MIL light come back on and codes are back to the very start!...that sensor? if it is driven much the DPF light will no doubt be back due to it not self cleaning.
  1. How to test coolant sensor loom for 5v?
    By TdiBlacky140 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-11-2019, 12:08 AM
  2. Question Engine speed sensor test G28
    By trickyd400 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-06-2019, 12:24 PM
  3. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  4. Fix Audi code 01032 Exhaust Gas Recirculation Sensor B & 01027 Exhaust Gas Rec Circuit
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2017, 02:57 PM
  5. oxygen sensor aging test for sensor 1
    By mkman1 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2014, 04:52 PM
