Thread: VW Polo 9n Fault codes on vagcom
  1. VW Polo 9n Fault codes on vagcom
    Dec 2019
    Chesterfield
    these are the codes that come up when i scan my car on vagcom and i was just wondering if anyone knows how to fix them i have googled them but not really got to the bottom of the problems that are still on the car report
    Code:
     Sunday,15,December,2019,12:47:41:00009
    VCDS Version: 19.6.2.0
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WVWZZZ9NZ5Y032031   License Plate: CJ04 LPX
    Mileage: 322340km-200292mi   Repair Order:
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ5Y032031   Mileage: 322340km-200292miles
    Address 01: Engine        Labels: 045-906-019-AMF.clb
       Part No: 045 906 019 BF
       Component: 1,4l R3 EDC 0000SG  5179
       Coding: 00002
       Shop #: WSC 00788
       VCID: 5AB1CFAAC61F709F89-4B18
       WVWZZZ9NZ5Y032031     VWZ7Z0D9921667
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
       Part No SW: 6Q0 907 379 R    HW: 6Q0 907 379 R
       Component: ABS 8.0 front   H03 0001
       Coding: 0000008
       Shop #: WSC 80093 222 69422
       VCID: 4C9D39F22CCB1E2F0B-5178
    1 Fault Found:
    16347 - Control Module - EEPROM Error
                014 - Defective
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0840
       VCID: 6AD19F6A167FE01F19-515A
    2 Faults Found:
    01596 - Motor for Outside/Recirculated Air Flap (V154)
                30-00 - Open or Short to Plus
                55-00 - Adaptation Not Successful
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q1 937 049 D
       Component: 0000 BN-SG.         1S34
       Coding: 05179
       Shop #: WSC 00186
       VCID: 3C7D69322C6BAEAFBB-513C
    Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
       Part No: 1C0 909 605 K
       Component: 0J AIRBAG VW51 0N   0008
       Coding: 12362
       Shop #: WSC 00788
       VCID: 2C5D5972DC0B3E2F2B-515A
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6Q0 920 900 G
       Component: KOMBI+WEGFAHRSP VDO V19
       Coding: 01432
       Shop #: WSC 00000
       VCID: 3261470AFE2F68DF61-513C
    Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
       Part No: 6N0 909 901
       Component: 001J GATEWAY CAN    1S34
       Coding: 00014
       Shop #: WSC 00788
       VCID: 70E58D0230A31ACF57-515A
    Address 44: Steering Assist        Labels: 6Q0-423-156.clb
       Part No: 6Q0 423 156 AB
       Component: LenkhilfeTRW        V270
       Coding: 10110
       Shop #: WSC 00186
       VCID: 6FE78E7E2D9D05374E-513C
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 G
       Component: 20 Komfortgerát     0002
       Coding: 00065
       Shop #: WSC 00788
       VCID: 3F871E3E3D7DB5B79E-4B18
       Subsystem 1 - Part No: 6Q1959801A
       Component: 20 Tőrsteuer.FS TFK 0004
       Subsystem 2 - Part No: 6Q1959802A
       Component: 20 Tőrsteuer.BF TFK 0004
    End-------------------------(Elapsed Time: 03:21)--------------------------
  2. Re: VW Polo 9n Fault codes on vagcom
    33 Post(s)
    729 Post(s)
    Which one are you worried about?
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  3. Re: VW Polo 9n Fault codes on vagcom
    Dec 2019
    Chesterfield
    Abs one but I replaced the hubs on both side fronts to get rid of the abs light but that fault always stays on when I run it on vag com
  4. Re: VW Polo 9n Fault codes on vagcom
    33 Post(s)
    729 Post(s)
    That is saying the Electrically Erasable Programmable Read Only Memory of the ABS ECU is faulty so it needs a new ABS unit.
  1. Replies: 8
    Last Post: 10-02-2017, 10:03 AM
  2. Important VW Polo 1.4 TDI misfiring (fault codes included in post)
    By wxyz in forum Polo - Derby - Lupo - Fox
    Last Post: 05-05-2014, 07:57 PM
  3. VAGCOM Fault Codes - what do they mean? - is she gonna blow?????
    By Dan Glibitz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-11-2012, 11:31 PM
  4. Replies: 2
    Last Post: 07-11-2012, 01:48 PM
  5. had the fault codes checked on vagcom
    By Hurley1611 in forum VCDS - General Questions
    Last Post: 26-02-2009, 08:33 PM
