Thread: VCDS is it suitable for me?
  1. VCDS is it suitable for me?
    May 2009
    cirencester
    With my recent troubles with my 2000 AJM golf mk4 115hp PD I'm thinking of purchasing some scanning kit. I also have a 2014 Passat b7 140hp bluemotion. I've been looking at the Rosstech VCDS (3 vin or 10 vin), is there any others to consider? Plus being a noob at this stuff am I going to be able to do anything with it without any sort if training?
    Many thanks.
  2. Re: VCDS is it suitable for me?
    Aberdeen
    48 Post(s)
    You could go for an older version like the Hex Can but if you get a new car you would need to change. Check out the Ross Tech site to see what is possible. It is all pretty straightforward just scan the car first and save that in case you change something and want to change it back later. The other thing it can do is release the rear electronic brake on the passat so you could change the rears yourself. This alone has paid for the cable for me.
  3. Re: VCDS is it suitable for me?
    Apr 2014
    SW London / Surrey
    51 Post(s)
    Depends what you want to do. I used mine initially to set a few convenience options like key opening door without sounding alarm, etc then trying to understand where various faults were coming from. It was useful for telling me the G65 sensor was bust on air conditioning and that aux heater had a problem that I quickly tracked to damaged power connection, but after two or three years of intermittent attempts to fix an "insufficient flow" on EGR I'm still not there. However, I can easily reset the indicator periodicallyto see if it is now fixed. Very useful when an MOT is due .
  1. Replies: 0
    Last Post: 03-06-2013, 08:04 PM
  2. Is this suitable oil for my '55 A4 3.0 TDI Q?
    By JetsetRon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-05-2013, 10:13 PM
  3. VAG COM Suitable for me?
    By Martin Burnard in forum VCDS - General Questions
    Last Post: 09-12-2008, 12:35 PM
  4. Question Is this gear oil suitable for a GT TDI?
    By the surfer in forum Golf MK5 - 2004 - 2009
    Last Post: 12-07-2008, 06:44 PM
  5. Where to buy suitable replacement..
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-08-2007, 03:13 PM
