Thread: Noisy and slight vibration on hard acceleration
  1. Noisy and slight vibration on hard acceleration
    Apr 2010
    Lancashire
    Hello all
    Got an issue 😡
    Under full throttle in 1st & 2nd when the turbo kicks kicks in the car gets loud and a vibration I can feel through the accelerator pedal. Normal driving is fine. Will pick up nicely at 1/2 pedal acceleration just when foot to the floor.
    The noise Sounds like exhaust is blowing/ load diesel. And feels like itís coming from passenger side of the engine or possible central.
    Itís a 2010 2.0tdi 170ps
    Any suggestions?
  2. Re: Noisy and slight vibration on hard acceleration
    Apr 2014
    SW London / Surrey
    30 Post(s)
    Difficult to say if it is the same, but I posted recently about a noise I get at ~2k RPM mainly in 1st / 2nd: Can anyone identify this noise on BKD engine?.
    Proposed as being Dual Mass Flywheel (DMF), which makes sense as it is noisiest when engine is driving hardest. If I'm at level speed or press clutch there is no major load on engine and noise stops. Noise comes from area you describe, and DMF is on lower left of engine on way to clutch / gearbox.
  3. Re: Noisy and slight vibration on hard acceleration
    Apr 2010
    Lancashire
    I thought DMF. It's only 1st and 2nd gear so probably something transmission related. I forgot to say it's a Manual if that makes a difference.
    The strange thing is the noise seems to only happen when the weather is bad, when driving in heavy rain when the roads are really wet. It's dry now and the noise seems to have sorted it's self out.
  4. Re: Noisy and slight vibration on hard acceleration
    Aug 2016
    Lisburn
    25 Post(s)
    run a scan see if the engine mounts are ok - check your inner CVs for play.
    Stewart
    2007 A6 quattro 3.0 TDI Manual
    1986 coupe quattro (kv) square wheels.
  5. Re: Noisy and slight vibration on hard acceleration
    Apr 2010
    Lancashire
    Thanks. Taking the car to a mechanic friend tomorrow to have a look over.
    The car has done 85K miles.
  1. Replies: 25
    Last Post: 25-04-2018, 07:32 PM
  2. Replies: 5
    Last Post: 22-08-2014, 06:46 PM
  3. Please Help Hard to start and slight hesitation
    By A3Quattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-05-2011, 08:52 PM
  4. Question Slight acceleration hesitation
    By Markdowl in forum Alhambra
    Last Post: 17-09-2010, 09:49 AM
  5. Noisy Rear end under hard acceleration
    By sabby12345 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-07-2008, 08:19 PM
