Thread: 80 cab auto cruise control not working
Results 1 to 10 of 10
  1. 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    Hi All
    my cruise conitro isn't working.
    Where red do I start ?
    vin
  2. Re: 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    Can anyone help with this ? I've been patient , I posted the question 2.5 years ago !
    can anyone tell me what should I be checking and in what order to figure out what is wrong with my 1999 80 cab 2.6 auto cruise control
    cheers
    vin
  3. Re: 80 cab auto cruise control not working
    108 Post(s)
    1816 Post(s)
    That is a very rare option, vacuum operated. I will have a look at the diagrams at work but the most common reason on this system was a vacuum leak, usually at the pedal valves. If you disconnect the vacuum line from the pump and apply a vacuum to the system, you should not be able to draw air much like when testing a TDI vacuum system.
  4. Re: 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    Thanks Crasher
    I know absolutely nothing about these vacuum systems . What is the purpose of the vacuum system and what is it used to control . Where is it normally pressured from ? (Or depressured if it’s a vacuum) what can you use to test them ?
    Vin
  5. Re: 80 cab auto cruise control not working
    108 Post(s)
    1816 Post(s)
    Could I have the VIN? It is actually extremely simple and easy to follow. The actuator which holds the throttle open is operated by a vacuum pump and the vacuum regulated by a control box with speed and switch inputs, the system is also quickly shut down by the vents in the pedal switches releasing the vacuum. I have seen very few of these over the years and even the 95 S2 I have in doesn’t have it, it was an option. We have a customer with a very early A3 1.6 and with cable throttle and cruise but these are bizarre. They use a motor in the throttle like cars only a year later use for all throttle control. Her TB is faulty and obsolete from Audi but we have managed to find one at VDO in Germany but for daft money and it is on its way.
  6. Re: 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    Thanks Crasher that's really helpful info . I will try and identify the parts under the bonnet tomorrow.
    The Vin number is WAUZZZ 8G z XK000889 8G7 0M8 (that's off the sticker in the boot)
    cheers
    vin
  7. Re: 80 cab auto cruise control not working
    108 Post(s)
    1816 Post(s)
    Checking cruise control vacuum system
    ‒ Pull off vacuum hose at vacuum pump.
    ‒ Press in diaphragm at actuator.
    ‒ Seal hose pulled off.
    ‒ There are no leaks in vacuum system if diaphragm at actuator remains pressed in and does not move.
    ‒ Vacuum system is leaking if diaphragm returns to original position.
    Possible causes of trouble
    ◆ Vent valve leaking or incorrectly set
    ◆ Actuator leaking
    ◆ Cracks in vacuum hoses
    1) Control unit
    2) Test connection with wire link. For production only. For automatic gearbox only
    3) Earth connection. Beneath dash panel
    4) Connector. Blue
    5) Linkage
    6) Actuator
    7) Vacuum hose
    8 Connector. For vacuum pump
    9) Vacuum pump
    10) Rubber grommet
    11) Vent valve at clutch pedal (not auto)
    12) Vent valve at brake pedal
    13) Brake light switch
    14) 26-pin connector, Black. For cruise control operating switch
    15) 26-pin connector. Blue. For dash panel insert
    16) Steering column switch with cruise control operating switch
    17) Dash panel insert, speed signal connection, blue connector, contact 18
  8. Re: 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    Thanks Crasher
    I will let you know how I get on that’s great info
  9. Re: 80 cab auto cruise control not working
    Sep 2008
    Highlands
    12 Post(s)
    I take it as mine is an auto it will be exactly the same except the vent valve at clutch pedal will be missing ?
  10. Re: 80 cab auto cruise control not working
    108 Post(s)
    1816 Post(s)
    This is the type 8D 1993 wiring diagram (I dug out the book of words because of having the S2 in so I scanned it for you) but I think it will be the same, yes the auto lacks the Y piece and clutch valve. First job for me would be checking fuse 12.
  1. Question Cruise Control stopped working - Multitronic auto
    By Rob-De-Banx in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-05-2018, 10:41 PM
  2. Cruise control not working
    By Mujnu in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-05-2015, 08:56 PM
  3. Cruise control not working
    By slabber in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2012, 10:40 PM
  4. Please Help Cruise Control Not Working?
    By ChrisH1098 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-10-2009, 01:26 PM
  5. A6 Cruise control not working
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-02-2009, 09:42 PM
