Thread: How to bleed A4 B6 power steering system
  1. How to bleed A4 B6 power steering system
    Liverpool
    11 Post(s)
    I assumed it was a simple 'jack it up and full lock left to right several times' but someone at work seems to think theres a specific rule to bleed air from the system (2003 3.0 V6 petrol engine, non quattro) that involves starting and stopping the car every few seconds or something? And also about filling the reservoir above the fill level to the top of the 'MAX' wording (top of the 'M')
    Any ideas please guys?
  2. Re: How to bleed A4 B6 power steering system
    Jan 2009
    Birmingham
    35 Post(s)
    this is what ive found
    MENU
    < PREV PAGENEXT PAGE >
    Bleeding steering system after repairs
    Different bleeding procedures are required after repairs to the steering system, depending on which components have been removed or renewed.
    After replacement of the entire steering system or steering box:
    Check hydraulic fluid level and top up if necessary.
    Raise vehicle until front wheels are free.
    Start engine briefly (max. 2 seconds)
    Pump must not draw in air; steering wheel must not be turned.
    Wait approx. 30 seconds each time before starting engine again.
    Keep repeating this procedure until fluid level remains constant.
    With engine switched off, turn steering wheel 10 times from lock to lock.
    Start engine.
    Turn steering wheel 10 times from lock to lock.
    Any air remaining in the steering system will dissipate by itself when the vehicle has been driven 10 … 20 km.
    When other steering components (except steering box) have been removed or renewed (e.g. pump, hoses, etc.):
    Start engine and allow to run for 2 - 3 minutes; do not turn the steering.
    Running gear, front-wheel drive and four-wheel drive > Steering > Checking fluid level, bleeding steering system and checking for leaks > Bleeding steering system after repairs
    MENU
    A4 Mk2
  3. Re: How to bleed A4 B6 power steering system
    1840 Post(s)
    That is actually a bit over the top but followed it will work well.
  1. Please Help How do i bleed the fuel system on a V6 tdi?
    By V6PASSATOWNER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2015, 12:28 PM
  2. bleed screws in cooling system
    By chimo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2010, 09:28 PM
  3. air bleed screws in cooling system
    By chimo in forum Touran - Sharan - Caravelle
    Last Post: 16-04-2010, 12:09 PM
  4. How to Bleed power Steering?
    By Gtiracer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2008, 08:48 AM
  5. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
