Thread: Bucking bronco. Vacuum problem?
  1. Bucking bronco. Vacuum problem?
    Dec 2019
    US ethridge
    Codes 16492 sensor g71 f96 signal too high. And 17963 charge pressure Max exceeded. The b5 1.8t a4 quattro. It's bucking and totally cutting off power after over boost. It only has 68k miles so I doubt the vain actuator is stuck open. I've heard faulty two way vacuum valves can mimic faulty n75 and stuck actuator. I need to know where these infamous valves are.
    Sent from my SM-G950U using Tapatalk
  2. Re: Bucking bronco. Vacuum problem?
    1840 Post(s)
    The turbo has a wastegate as it is not a VNT unit so no VANES, if it was stuck open you would have underboost. Check the charge pressure control lines to the N75 and the wastegate actuator are in good condition.
  3. Re: Bucking bronco. Vacuum problem?
    Dec 2019
    US ethridge
    Thanks crasher. Do you have a link showing how to access the waste gate linkage?
  4. Re: Bucking bronco. Vacuum problem?
    1840 Post(s)
    It is the can on the side of the turbo.
  1. Please help A4 B6 bucking and then stalling at the lights
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-10-2018, 10:03 AM
  2. Audi 80 tdi juddering bucking jerking
    By avanttdi in forum 80 - 90
    Last Post: 24-10-2014, 10:17 AM
  3. Bucking Skoda Octavia Please Help!!!
    By 220sugars in forum Octavia
    Last Post: 28-07-2013, 11:37 PM
  4. Golf MK4 lurchin/bucking
    By Yelloperil in forum Golf MK4 - 1999 - 2004
    Last Post: 17-12-2008, 10:48 PM
  5. audi 80 tdi bucking jerking
    By micheal balbrig in forum 80 - 90
    Last Post: 30-12-2007, 06:56 PM
