Thread: Sharan wiper/blower not working
  1. Sharan wiper/blower not working
    The wipers, blower, rear demist and passanger compartment blower have suddenly stopped working. I have checked all the fuses (all ok) and don't know where to look next. Model - 1999 VW Sharan. I have just cured (thanks to this site) a water leak into the footwells which affected the central locking . Don't know if this is a related fault. Any help would be much appreciated.
  2. Re: Sharan wiper/blower not working
    boston lincolnshire
    hi
    sorry i dont know the answer to your problem but you maybe able to help me i have a leak in the passenger footwell and my central locking is playing up as well also my heater blows hot and cold but it doesnt demist my windscreen it keeps misting up whilst im driving any ideas
  3. Re: Sharan wiper/blower not working
    I went through a similar problem, would start by looking under the bonnet and look for water lying on a shelf just below windscreen if water lying there try clearing the drain holes either side ,water can find its way in through pollen filter located on right hand side as you stand at front of vehicle the drain holes are not easy to get at but persevere they are there, ,a metal coathanger straightened out is good,,if not that then if you are losing water from system as well i would suspect that your heater matrix may well be scuppered
  4. Re: Sharan wiper/blower not working
    First cure your water leak, as jaybee suggests - mixing water & the sometimes delicate electrics in these cars is not a good idea.
    Your demist is probably not working as your car is saturated with water vapour, fix the leak, dry the car and it should be okay.
    The electrics issues maybe due to connectors shorting out, loom damage from shorts, relays with water inside etc. etc.
  1. Sharan - Heater Blower Motor Brushes
    By Paul Sharan in forum Touran - Sharan - Caravelle
    Last Post: 18-02-2009, 10:39 PM
  2. Passat TDI 130 2002 Interior blower vent lights not working!
    By radek2008 in forum Chat - Anything with wheels
    Last Post: 19-10-2007, 07:00 PM
  3. Wiper Water low - Alert not working..
    By alex130tdi in forum Chat - Anything with wheels
    Last Post: 17-09-2007, 03:09 PM
  4. Washer fluid and wiper arm not working?
    By johnvdub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 08:56 PM
  5. Rear Wiper stopped working
    By Slur in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2007, 03:38 PM
