Thread: Headlight restoration
  1. Headlight restoration
    Liverpool
    11 Post(s)
    I've had to clean/polish my headlights with a bit of success, but will be redoing them this weekend weather permitting. Question, once polished to within an inch of their life, do you guys treat them with a clear laquer or sealant to prevent them fading again?
    Or would sealing them eventually burn off over time?
  2. Re: Headlight restoration
    1840 Post(s)
    I use the Maguires kit followed by the Optima restoration wipe kit which is frankly bloody marvelous although I use one kit per headlight. You MUST keep them warm and dry for at least four hours and do not touch until dry or try to apply a second coat until fully cured which is a few weeks. When fully cured, I treat them to a coat of Rain X as I found the coating did not bead particularly well and on Mrs Crashers 06 Polo GTI, after a second coat and Rain X they look almost like new.
  1. 3M headlight restoration kit
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-11-2012, 09:13 AM
