Thread: Another P2015 Problem :( - Engine light ON
Results 1 to 10 of 12
  1. Another P2015 Problem :( - Engine light ON
    Mar 2017
    Hemel Hempstead
    Hi All,
    I'm recently purchased an Audi a4 b8 with a few problems which I need to solve. Biggest one for me atm is the P2015 problem.
    Things I've done:
    1.) Bought a VAG COM
    2.) Changed the v157 motor with a second hand one (P2015 bracket already installed). Unfortunately it did not solve the problem.
    3.) I bought a brand new v157 motor.
    Before paying to change the motor again.. I was hoping to get a little advice.
    My mechanic has recommended that I also change the swirl flap lever thing which the V157 motor spring connects to as this can sometimes be the issue... looking on fleabay I found a swirl flap repair kit
    AUDI VW SEAT SKODA 2.0 TDi INTAKE MANIFOLD 03L129711E /AG SWIRL FLAP REPAIR KIT | eBay
    This is a little extortionate I thought as its £46 for a piece of plastic and a spring.
    Is there somewhere I can source these parts at more reasonable prices or should I just change the intake manifold with a second hand one? Also is there anything else I could try to tell whether this is really the problem? Could I do anything else to debug the problem?
    Any help is greatly appreciated!!!!
    Thanks Aj
  2. Re: Another P2015 Problem :( - Engine light ON
    Mar 2017
    Hemel Hempstead
    any help would be greatly appreciated ???
  3. Re: Another P2015 Problem :( - Engine light ON
    Jan 2009
    Birmingham
    35 Post(s)
  4. Re: Another P2015 Problem :( - Engine light ON
    1836 Post(s)
    The problem is the V157 is no longer the anti shudder flap, it is the motor on the side of the inlet manifold and VAG do a delete kit.
  5. Re: Another P2015 Problem :( - Engine light ON
    Mar 2017
    Hemel Hempstead
    Thanks for the reply, I actually change this motor with a second hand one. I have a new one.. but this delete idea sounds good! Do you by any chance know of a guide I can show my local mechanic to do it?
    Also if there are any decent mechanics in Hertfordshire or North London??? it would make things so much easier
    Thanks Aj
  6. Re: Another P2015 Problem :( - Engine light ON
    1836 Post(s)
    There is a genuine kit to do it, private message me your reg number. I have done quite a few on CAYC engines
  7. Re: Another P2015 Problem :( - Engine light ON
    Mar 2017
    Hemel Hempstead
    dropped you a message in your inbox mate.
  8. Re: Another P2015 Problem :( - Engine light ON
    1836 Post(s)
    No I was wrong on this one, the V157 is still the flap unit before the EGR valve and the inlet manifold is V183 with G513. The V157 is VAG part number 03L 128 063 AF, what did you fit?
  9. Re: Another P2015 Problem :( - Engine light ON
    Mar 2017
    Hemel Hempstead
    Just the motor which by the looks of things fits before the throttle body
    To be precise ... I had the following part fitted ->
    VW 03L 129 086
    For AUDI A3 A4 A5 A6 Q5 TT 2.0 TDI Intake Manifold Flap Actuator Motor NEW | eBay
  10. Re: Another P2015 Problem :( - Engine light ON
    1836 Post(s)
    Originally it would have been 03L 129 063, then B, C, D, E and finally AF. The part in the link is the manifold motor V183/G513, not the V157 throttle body. 03L 129 086 does not exist.
  1. Please Help Audi A4 1.8TFSI P2015 engine management light.
    By RichardSharp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2021, 09:29 PM
  2. Audi A3 2.0TDI P2015 code Engine not starting
    By Rachey1984 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-10-2019, 06:33 PM
  3. Please Help DPF problem with engine light on...
    By nowa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-11-2013, 09:59 AM
  4. Engine Management light...MAF problem?
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2009, 02:56 PM
  5. golf engine management light problem
    By HUTCH in forum Chat - Completely Off Topic
    Last Post: 07-11-2006, 07:04 PM
