Thread: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    I tried it with a set of jump leads attached and also with another new battery with no luck. There are no fault codes at all on VCDS. Very strange.
  2. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    1840 Post(s)
    No immobilser warning light or "Safe" text in the trip mileage recorder? Have you checked the fuel filter is full and run both electric fuel pumps to ensure they work and they are delivering fuel to the HPFP? Have you had the connections off the top of the fuel tank fuel delivery unit?
  3. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    Thanks Crasher, definitely no SAFE on the dash. Fuel filter full and will check the pumps tomorrow. Will also have a look at the fuel tank delivery unit too. Thanks again.
  4. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Nov 2020
    Scotland
    Hi there did u ever find the fault for this problem I have same issue and any help would be great thanks 1.6tdi golf
  5. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    How many miles are on your golf? Also what year is it? Did you get a scan done? I suspect it’s an EA189 car?
    The customer didn’t want to spend any money having it looked it, so took it away and sold it cheap as a non runner. I don’t know what happened to it and I’ve not seen the fault appear anywhere in other cars since. First thing I would do is change the Egr valve and see what happens.
  1. Question 1.6tdi CAYC Engine
    By djah in forum Golf MK6 - 2009 - 2013
    Last Post: 11-07-2019, 05:20 PM
  2. Please help vw passat 1,6tdi cayc
    By dorin in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 08-03-2018, 09:23 AM
  3. Question 2010 VW Polo 1.6 tdi, starts up but only runs for 2 seconds then stops
    By B1llyboy in forum Polo - Derby - Lupo - Fox
    Last Post: 13-12-2017, 07:37 PM
  4. a6 2.6 playing starts stops and no starts
    By jolleyalex26 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 12-10-2010, 08:43 PM
  5. Audi 80 auto 1.8 starts for 2 seconds then stops
    By timnewton30 in forum 80 - 90
    Last Post: 10-08-2008, 05:35 AM
