Thread: Vibration on braking
  1. Vibration on braking
    Brighton, United Kingdom
    Hi. I've been having a problem with my 2002 Leon MK1 and vibration when braking. The rear brake discs were pitted and pads worn so have been replaced. The front pax side wishbone had movement so was replaced. The wheel alignment has been done. The front brakes look fine, plenty left on the pads. Still having the problem. Could it be warped discs on the front? I think from memory they are 2-3 years old. Any easy ways to check this? Thanks.
    Sent from my SM-N960F using Tapatalk
    1.6 16v S W2000reg AUS .
  2. Re: Vibration on braking
    1840 Post(s)
    It is a common issue with the 288mm discs on the PQ34 platform, you need a dial gauge.
    What you MUST do is also check the hubs for run out, especially on the outside edge of the wheel bolt holes, it is hard to find a spec but I once read (and can no longer find) the maximum disc outer edge runout on a car with ABS is 0.03mm..... which is not a lot! On a hub, you need to see absolutely no runout at all.
    Replacement hubs are of an improved design
    1 1 0
  3. Re: Vibration on braking
    Thanks for the info, I will look into that.
  1. Audi A6 vibration when braking????
    By Mikeyg82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-08-2021, 04:20 PM
  2. problem with vibration when braking
    By noogman in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-01-2016, 12:26 PM
  3. Strange Vibration Under Braking
    By audi-nutz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2014, 10:47 AM
  4. Passat braking vibration and knocking
    By samcaravelle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 08:04 AM
  5. Braking vibration but not discs.
    By Little Old Me in forum Touran - Sharan - Caravelle
    Last Post: 15-12-2008, 11:43 AM
