Thread: Tailgate catch actuator.
Results 1 to 9 of 9
  1. Tailgate catch actuator.
    Feb 2019
    Bexhill, England
    Are the catch actuators repairable? I have recently put a new catch and connected the actuator arm that had previously (prev owner) disconnected.
    For a while I was able to open the tailgate by using the boot handle but now it doesn’t seem to work. I can hear noises when I use the handle so I know electric power is present.
    I have taken the actuator off and can manually push the piston in and I can see the big wheel turning through the opaque plastic cover.
    l guess this means there is a problem with the ‘worm drive’?
    I can’t see any obvious means of opening the unit up without trashing the case? Has anybody had one of these apart? Any point in doing so?
    If relevant, I have a 2003 A4 Avant Estate B6.
  2. Re: Tailgate catch actuator.
    Feb 2019
    Bexhill, England
  3. Re: Tailgate catch actuator.
    Near Blackpool
    48 Post(s)
    They are pence from eBay. Just chuck a new one on
  4. Re: Tailgate catch actuator.
    Feb 2019
    Bexhill, England
    Quote Originally Posted by jonathanfenton View Post
    Well, the ones I am seeing are about £28?
    Anyway, I warmed the actuator (A) up and prized off the casing.
    The problem seems to be that the A opens once and then runs out of puff if used again in a short space of time. Maybe the return mechanism?
  5. Re: Tailgate catch actuator.
    Feb 2019
    Bexhill, England
    I always seem to hold my iPad upside down when taking a picture. ��
  6. Re: Tailgate catch actuator.
    Near Blackpool
    48 Post(s)
    I bought one by mistake from amazon for around £10 I think. In my garage somewhere lol. Kudos if you fix it but I’d seriously just throw a new one in.
  7. Re: Tailgate catch actuator.
    Feb 2019
    Bexhill, England
    Nearly ‘lost’ the return spring!
  8. Re: Tailgate catch actuator.
    Feb 2019
    Bexhill, England
    It’s working better than it did (having smeared the moving parts in silicone grease) but it’s not working for more than two opens without having a rest. I’ll put it back on pro tem and get online and have a look for a replacement.
    Oh well, I tried. And failed. Again.
  9. Re: Tailgate catch actuator.
    Near Blackpool
    48 Post(s)
    DM me your address. I’ll send you this one. It’s the same part number but newer so a C
  1. Tailgate catch ‘actuator’.
    By Finless in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2019, 06:38 AM
  2. How To Golf MKiv estate boot catch actuator problems / rear washer leak
    By wcubbin in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2013, 05:42 PM
  3. Tailgate actuator
    By Rob-b in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-10-2012, 03:26 PM
  4. Replies: 6
    Last Post: 28-06-2012, 04:31 PM
  5. Question rear tailgate lock actuator
    By croft100 in forum Alhambra
    Last Post: 22-01-2012, 08:44 PM
