Thread: VCDS Help Stourbridge for my (elderly) parents
  1. VCDS Help Stourbridge for my (elderly) parents
    Nov 2019
    Ely
    Good evening,
    My (elderly) parents have my old 2006 Audi A3 Sportback and have an issue with battery drain of 1 amp / per hour. There are intermittent issues with instrument cluster not working, wipers not working etc. Has had 3 new batteries within the last couple of weeks. First died within a day with a bad cell and then two more from RAC after that. When fuse F6 is removed, the 1 amp / per hour drain stops. Fuse has been cleaned with emery cloth and when fuse added, the drain was much lower then goes back to 1 amp / per hour. I'm about 200 miles away from them so can't really help apart from googling and talking over the phone. Logic is now pointing towards the instrument module or cluster being faulty; I initially thought it was the convenience module in boot.
    Firstly, does anyone have any suggestions on anything else to test or secondly, is there anyone near Stourbridge that has VCDS that might be able to help out for some beer tokens? They are getting stressed with it and threatening to scrap the car - it has only done 70K miles and has been fault free right up to this point.
    Any help or advice will gratefully be received by both myself and my parents!
    Many thanks in advance.
    James
  2. Re: VCDS Help Stourbridge for my (elderly) parents
    Nov 2016
    Ireland
    14 Post(s)
    So fuse F6 controls the instrument cluster and module,,, anything else? Can you unplug the individual items on the circuit to see which ones stops draining?
  3. Re: VCDS Help Stourbridge for my (elderly) parents
    Nov 2019
    Ely
    I will see if I can get him to remove the cluster tomorrow and unplug it and see what happens. Could a faulty cluster cause a drain on the battery?
    It's quite difficult trying to communicate these things over the phone with them lol.
  4. Re: VCDS Help Stourbridge for my (elderly) parents
    Aberdeen
    63 Post(s)
    Try checking the alternator too. Poor earth or fault could cause a draw. Also, might be a broken wire in the door which prevents the car going into sleep mode (bit of a guess)
  5. Re: VCDS Help Stourbridge for my (elderly) parents
    Nov 2019
    Ely
    A bit of an update - car has been scanned and had to have a second scan due to the fuses being removed / replaced etc.
    Quite a few errors have been thrown up and think that instrument cluster might be main culprit but I'm not totally sure. Would anyone be able to comment on the log provided here?
  6. Re: VCDS Help Stourbridge for my (elderly) parents
    Aberdeen
    63 Post(s)
    Somebody with better knowledge of VCDS might give you an answer here but the Ross Tech forums is a good place for help and information on the VCDS
  7. Re: VCDS Help Stourbridge for my (elderly) parents
    Apr 2012
    Isle of Skye
    My Wife had an issue with a MK5 GOLF that due to a flat battery fried something in the instrument cluster due to voltage spike, we had all manner of faults and non start, I narrowed it down to the instrument cluster. I removed it and sent it away to this company below in the link. They tested and repaired the instrument cluster with a guarantee , I refitted and all good. It was much cheaper than a new part from VW that would also need coding as blank and could only be done at a dealer due to immobiliser / security. I have no connection with the company, part from being a happy customer.
    Good luck.
    Jason
    https://www.actronics.co.uk/instrument-clusters/audi-a3-8p-2003-2012
  1. Anyone near Stourbridge?
    By Richard_uk in forum VCDS - Help Requests
    Last Post: 03-06-2016, 08:13 PM
  2. TVS Cars Stourbridge
    By Matt A4 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 16-03-2011, 01:40 PM
  3. Vw stourbridge are they any good?
    By Mini Mark in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 17-09-2010, 01:46 PM
  4. Elderly A6 needs a bit of TLC to revive
    By DSM in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-04-2009, 09:32 PM
  5. why parents drink
    By philla4tdi in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 24-10-2008, 07:56 PM
