Thread: 2012 A7 no heater from either side
  1. 2012 A7 no heater from either side
    I read the article on heat on side, I have no heat on either side.
    I had it in the garage today, they didnt seem too confident and said it was probably the mechanical water pump - apparently there is an electric one also.
    So if the temp gauge gets to 90 and stays there - even on tick over etc it just doesnt budge I am ont convinced it is the water pump.
    Does anyone know where the water feeds from the engine, what valves it passes through and what flaps there are ?
    Any ideas on the problem anyone or any links to look at ? I've search the interweb and cant find anything
  2. Re: 2012 A7 no heater from either side
    Oct 2019
    Peterborough, England
    19 Post(s)
    I thought it was supposed to get to 90 and stay there?
  3. Re: 2012 A7 no heater from either side
    yes it does. Garage tried t convince me it was water pump
    Now have heat from RHS (Drivers in UK) but nothing from passenger.
  4. Re: 2012 A7 no heater from either side
    Dec 2015
    Southend, UK
    I cant think it's the water pump- or at least not the main, mechanical coolant, water pump.
    What has changed for you now to get heat from the right hand side of the heater, what work was carried out ?
    Try now swapping the left and right hand side temperature sensors over (they are just behind the left and right vents each side). If the right now stays cold and the left heats up then its a dodgy sensor.
    Have you checked for fault codes with a VAG Com (or similar) ?
    Try flushing the system out as described in the other thread and check for any improvement. (You only need an hour and access to a hose pipe, some pliers for the hose clip)
  1. Heater working one side only
    By Not_Anumber in forum A7 - S7
    Last Post: 18-12-2019, 03:37 PM
  2. heater fault - hot on one side, ok the on the other
    By davidlandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-12-2012, 04:52 PM
  3. Question heater blows cold on driver side but hot on passenger side.
    By pudsey28 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-08-2011, 09:37 AM
  4. Please Help Heater blowing cold air on one side hot on other
    By rushyo1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-02-2010, 11:07 PM
  5. Heater only blowing hot air on passenger side
    By stuartt0712 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-04-2009, 08:16 PM
