Thread: P256300 turbocharger Boost control position sensor vw Passat
  1. P256300 turbocharger Boost control position sensor vw Passat
    Nov 2019
    Nottingham
    Hi there everyone. I have put a new turbo in my Passat 1.6tdi 2012 CAYC and the code p256300 turbo boost control position sensor as come up . I changed the actuator from the old turbo aswell and same code popped up with my coil light flashing and engine management light. I have also tried adaption via vcds and still no luck. Any no the proper procedure as I am struggling with be nice if someone can help
    Thank you
  2. Re: P256300 turbocharger Boost control position sensor vw Passat
    Aberdeen
    49 Post(s)
    I have moved your thread to the correct forum section.
  1. 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    By lcf666 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-03-2019, 10:28 PM
  2. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-09-2018, 09:48 AM
  3. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum New Member Introductions
    Last Post: 29-08-2018, 12:21 PM
  4. Replies: 0
    Last Post: 26-04-2018, 11:45 AM
  5. Boost Control Valve for Turbocharger
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2010, 10:32 PM
free web
stats
