Thread: 3.0tdi throttle body part number
  1. 3.0tdi throttle body part number
    Feb 2009
    northumberland
    I’m getting p0638 fault code and light on dash.
    My throttle body is part number is
    4E0145950H. I can get a new throttle body with same part number but last letter is C not H..
    Would this be ok or do I need version H ?
    The code refers to open circuit, what does this mean?
    I cant get to garage for proper vcds scan for a while so have no more details.
    The car drives perfectly well at the moment.
    Any help appreciated.
    Mand
    66 plate A4 3.0tdi quattro S line
    16 plate A6 3.0tdi quattro s line - gone @ 23.5k
    58 plate A4 3.0tdi quattro se, leather sports seats, no other goodies - gone @ 139k
    56 plate A3 2.0T quattro s line - gone @ 50k
    Y plate A6 2.5tdi quattro sport - gone @ £145k
  2. Re: 3.0tdi throttle body part number
    Apr 2009
    As a general rule the part numbers are backwards compatible but not forwards, you should try and find a part with the same letter suffix or higher
    Sent from my MI 6 using Tapatalk
    Audi A4 Avant 2.0 TDi 2009
  3. Re: 3.0tdi throttle body part number
    Feb 2009
    northumberland
    Suspected that would be the case.
    thanks
  4. Re: 3.0tdi throttle body part number
    Feb 2009
    northumberland
    Got another question.
    To get the original part number I had to take my throttle body off.
    Whilst it was still electrically connected but not in place I turned the ignition on an off without starting the engine and the flap didn’t move. Did the same again with engine fired up and flap didn’t move.
    Should it have moved in both cases?
  5. Re: 3.0tdi throttle body part number
    Aberdeen
    63 Post(s)
    I thought it only opened with the accelerator moving. Have you thought about cleaning it?
  6. Re: 3.0tdi throttle body part number
    Feb 2009
    northumberland
    I did clean it but it wasn’t that dirty for 138k miles.
    I expected the flap to close when turning off, then spring back open.
    Cars currently at my local indie garage
    Fingers it’s not too costly..
  7. Re: 3.0tdi throttle body part number
    Feb 2009
    northumberland
    Quick update.
    My independent garage fitted a new throttle body (not purchased from Audi due to it being £450).
    They confirmed it works but still getting an open circuit fault and car not running right.
    Seems like the flap is being told to operate incorrectly. After 2 weeks they’ve not got to the bottom of it, and now say the dpf light is on as it’s knackered.
    So I’ve put the original throttle body back and traded the A4 for a A6, as was looking to change cars soon.
    See you in the A6 forum.
  8. Re: 3.0tdi throttle body part number
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Your original fault code stated " open circuit " which could have been a faulty throttle body electrically, or a fault in the wiring between the ECU & throttle body.
    As your garage has changed the throttle body that just leaves a wiring fault.
    The ECU won't instigate a regen while the throttle body fault is present, so that also explains that problem.
    Sorry for not being able to reply to your problem earlier.
  9. Re: 3.0tdi throttle body part number
    Feb 2009
    northumberland
    No worries, was changing cars soon anyway..
  1. Please Help New throttle body, genuine Audi part or Pierburg?
    By crispo99 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-09-2016, 03:36 PM
  2. 2005 audi a6 3.0tdi quattro auto throttle body replacement
    By bizzleb109 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-07-2015, 12:51 PM
  3. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  4. Urgent:Throttle body part number required please..
    By xpeterpx in forum Bora - 1998 - 2005
    Last Post: 12-06-2009, 09:05 AM
