Thread: Running lean
Results 11 to 20 of 34
  1. Re: Running lean
    1836 Post(s)
    As I said, for all four to fail equally would be unheard of...
  2. Re: Running lean
    Dec 2017
    Lochgelly
    I understand that, but what if it's only one that's failed, wouldn't it be the same symptoms was what I meant?
    Sent from my SM-G965F using Tapatalk
  3. Re: Running lean
    1836 Post(s)
    If one has failed to that degree I would expect the cylinder to underperform and the ECU should pick this up as the firing speed would change and would then the ECDU would be able to identify the suspect cylinder and shut off the injector concerned which would then give you a proper misfire. If it is not obviously down on one cylinder I think code is indicating it is an overall lean running condition from all four cylinders.
  4. Re: Running lean
    1836 Post(s)
    Which year and engine code is it?
  5. Re: Running lean
    Dec 2017
    Lochgelly
    Ok that makes sense, so I can pretty much rule that out as being my issue just now, it's a 2007 s3. BHZ engine code. I have tested the Pcv delete yesterday, as i closed off all its access to any metered air and there is definately no unmetered air making it's way from my Maf to my turbo inlet.
  6. Re: Running lean
    1836 Post(s)
    I will have a think.
  7. Re: Running lean
    #17
    Dec 2017
    Lochgelly
    Thankyou. I'm at a dead end.
  8. Re: Running lean
    #18
    1836 Post(s)
    So you pressure tested the system at 0.5 Bar? I can't quite wrap my head around the concept of introducing an air leak stopping a lean running condition...
  9. Re: Running lean
    #19
    Dec 2017
    Lochgelly
    Yes. The only sense i can make of it is my fuel system can't keep up with all the air. So get rid of some of the air and my ltft comes right now to 3 I think it was, and it runs spot on.
  10. Re: Running lean
    #20
    1836 Post(s)
    That was running through my mind as well but I dismissed is based in it was OK before, I wonder if the fuel pressure is low? Not low enough to trigger a code but low enough to not keep up with the mapping?
  1. Running lean tryed everything
    By troyritsema in forum 1.8T - Engine
    Last Post: 07-01-2018, 07:54 PM
  2. P0171 system running lean. Help please?
    By tobyg123123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-02-2017, 07:46 PM
  3. Audi S6 running lean
    By alinomie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-09-2010, 04:59 PM
  4. Please Help Golf 1.6 SE 8 Valve Running lean
    By obx102 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2008, 03:15 PM
  5. Please Help MK3 ABF Running too Lean
    By Golf-Fiend in forum Golf MK3 - 1993 - 1999
    Last Post: 09-05-2008, 05:50 PM
