Thread: A8 suspension problem-help please
  1. A8 suspension problem-help please
    Nov 2019
    I have a A8 2013 model partial scan below for relevant errors if anyone could shed some
    Light please.
    issue is amber suspension error and scanned with VAGCOM
    car looks level on passenger side but on drivers side is high on rear
    but on front is a bit low possibly because the back is so high.
    car has remained like this and looks like it’s not sunk at all.
    After the scan error looks like it’s not letting air out of the rear?
    Wanted to start with getting a garage changing the pressure valves
    if that’s an option. Don’t really want to have massive bill for diag
    As last garage did not have a clue and wanted to spend an endless amount of my dime
    on checking by pulling the car apart learning.
    Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
    Part No SW: 4H0 907 553 E HW: 4H0 907 553
    Component: LUFE-DAEMPFER H17 0099
    Coding: 008000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_AirSuspe 003024
    ROD: EV_AirSuspe_VW51.rod
    VCID: 2E06073D809FD2B76BB-807A
    4 Faults Found:
    357643 - Bleed Valve for Ride-Height
    C103B 13 [009] - Open Circuit
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 7
    Reset counter: 174
    Mileage: 475080 km
    Date: 2019.11.06
    Time: 00:14:30
    677123 - Ride-Height System
    C1047 07 [008] - Mechanical Failure
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 214
    Mileage: 475080 km
    Date: 2019.11.06
    Time: 00:12:53
    357655 - Bleed Valve for Ride-Height
    C103B 11 [008] - Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 214
    Mileage: 475080 km
    Date: 2019.11.06
    Time: 00:12:38
    403200 - Function Shut-Off Active
    C10C8 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 214
    Mileage: 475080 km
    Date: 2019.11.06
    Time: 00:12:45
    0 0
  2. Re: A8 suspension problem-help please
    Oct 2019
    Peterborough, England
    23 Post(s)
    Hi, does the car rise and fall on command?
    And also, do you feel a difference in ride from dynamic to comfort mode?
    It might be better to check the suspension ride height sensor jobbies rather than dive into the pressure valves straight away.
    Take the right rear off, clean it and stick it back on?
    I know on the D3s, that was quite a quick and easy job.
  3. Re: A8 suspension problem-help please
    1840 Post(s)
    I have seen that where water gets into the air valve in the left front inner wing and rots the wiring.
  4. Re: A8 suspension problem-help please
    Oct 2019
    23 Post(s)
    Oh, also...is that mileage right? For a 2013? 475080 km? Wow!
  5. Re: A8 suspension problem-help please
    1840 Post(s)
    Quote Originally Posted by A8Cruiser View Post
    I hadn’t noticed that.... leggy
  1. Air Suspension problem
    By careless_adi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-08-2014, 10:37 AM
  2. Air suspension problem
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-08-2013, 10:24 PM
  3. Question Air Suspension Problem
    By abyrne153 in forum A8 - S8 - V8
    Last Post: 02-05-2013, 09:52 PM
  4. suspension kit problem
    By tbs in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2010, 02:24 AM
  5. Please Help Possible problem with suspension
    By slinger247 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2008, 01:10 PM
