Thread: Audi A7 Night Vision Retro Fit
  1. Audi A7 Night Vision Retro Fit
    Nov 2019
    Hello all - new to this forum...
    im looking to do NV retro fit on a 2017 facelift A7. i have located the camera, module (goes under passenger seat?), cable for camera, and headlight switch and need some help on what else is required.
    the vehicle has HUD/side assist/lane assist/brake assist/advanced parking/etc, in fact almost everything apart from night vision!
    how can i find out if the instrument cluster will need replacing or if what i have already has the required functionality?
    as far as the fitting is concerned, fitting the camera is no issue to me (taken bumper off before thanks to a muntjack!!). however i would also like some help on the following:-
    1. where exactly does the control module go?
    2. what is the cable route from the camera to the module, or is this already in the loom?
    3. what connections need to be made to the instrument cluster?
    4. what other parts do i need.
    thanks in advance for any help!
  2. Re: Audi A7 Night Vision Retro Fit
    Nov 2019
    Hello Andy
    thanks for your message - i wrote a long reply but it seems to have vanished as i have now discovered that i cant PM you because i havent posted more than 10 times yet!
    is it possible to converse by email or something? obviously you can PM me but i cant reply. if you dont want to email i understand.
    basically i am trying to get all the ducks in a row. i dont want to start something that turns out to be impossible or very expensive.
    i have found the camera, camera bracket inc washer, module, module bracket, camera cable, module power cable all on ebay for around £800. the grille i think can take a camera without needing new parts (maybe a bit of dremel surgery). i will need to connect the washer to the headlight washer system but i cant find the part number for that. the A7 C7 never had VC but did have NV so i just need to know if the instruments i have can do NV. i suspect that because i have most if not all the other safety options i probably wont need the gateway bit, or hopefully new instruments. how cann we check the instruments?
    thanks for your help andy and sorry i cant PM you!
  1. Night Vision RetroFit
    By andyhud007 in forum Q7 - 4M Forum - 2016 -
    Last Post: 04-05-2023, 10:30 PM
  2. Question Audi A6 Avant 4G 2012 ACC + LANE + Night Vision retrofit
    By XPepino in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-11-2019, 01:51 PM
  3. Night vision and pre sense failed.
    Last Post: 12-01-2017, 09:44 PM
  4. What is this? (my guess something to do with night vision)
    By belly buster in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-05-2015, 03:45 PM
  5. Audi a6 2012 night vision problem.
    By m-a-t-o in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2014, 03:07 PM
