Thread: Rear Fog lights, number plate light and boot won't open
  1. Rear Fog lights, number plate light and boot won't open
    Morayshire, Scotland
    Hi: Ive seen the same problem on this forum but no actual fixes mentioned. The multi function display says both rear fog lights and number plate light are faulty and sure enought they are not on. Also I cant open the boot the usual way but can with the key. When I open the boot a little way, the number plate light comes on and the fog lights work as well. The boot is then able to be opened the usual way and the multi function display is happy. After a couple of start/stops the same happens again.
    I don't know if this is relevant, but with the boot lid lights working, if I open the boot lid until the interior light comes on, the boot lid lights go out, is this normal.
    Thanks guys , I hope someone has the fix for this. Thanks.
  2. Re: Rear Fog lights, number plate light and boot won't open
    Southern County Softy
    16 Post(s)
    Check the loom by the NS hinge for broken wires.
    A4 2.5 tdi QS (mapped)
  3. Re: Rear Fog lights, number plate light and boot won't open
    Hi Kite: Great advice. Once I cut back the rubber bendy tube around the loom I found a broken brown wire. It was thicker than the other wires so I expect it was the earth wire. There was also another wire with damaged insulation so it was worth looking at. All seems fine now thanks.
  1. Rear Fogs, Number plate lights and Boot Central locking all not working??
    By colinraj11 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-11-2017, 09:31 PM
  2. Rear number plate lights
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-05-2014, 08:16 PM
  3. Allroad rear fog lights and number plate lights problem
    By bootie3367 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2013, 10:08 AM
  4. Rear number plate lights
    By PatMcCoy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-08-2011, 11:38 PM
  5. Boot lid light and number plate light panel
    By Walesgbn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-01-2009, 08:33 PM
