Re: Calling facelift tech pack owners - need a VCDS scan please... –
18-11-2019,05:22 PM
Originally Posted by
Adman
After a favour... I've just chopped in my 2013 A6 for a 2016 BiTDi. Unfortunately it doesn't have the tech pack which i had on my previous A6 which i really got a lot use out of, so looking to retrofit. Before you say why didn't you just by the car with it already fitted, well i have been searching for months and couldn't find one with colour, spec, mileage i wanted and frankly got tired of waiting.
If someone with a facelift and tech pack could provide an old scan to show what part no.s they have, i can then research it from there. I have the scan from my old pre-facelift A6 so have that, but from what i can see the components are not the same but will stand corrected.
Any help much appreciated.
Ad
Here is a scan from my old UK 2016 A6 facelift. It had Tech Pack Advanced, Parking Pack Advanced, Matrix LED, Ambient Lighting, Speed Limit Display and a lot of other stuff too.
Hope it gives you what you need!
MF.
Code:
Monday,16,October,2017,15:30:22:07948
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ4G2GN139260 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 52
53 55 5F 62 6C 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G2GN139260 Mileage: 29560km-18367miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 1649
Revision: 85H23---
Coding: 0A254012244401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ_002.rod
VCID: 79F2E728F8C65E8ECD-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4G1 927 153 B HW: 0CK 927 156 S
Component: 0CK 20TDI RdW H04 0002
Revision: --H04--- Serial number: 0000000421
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002020
ROD: EV_TCMDL382021_AU57.rod
VCID: 2952F76848E62E0EFD-807C
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP HB1 0572
Serial number: 75117051150260000373
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 06A29E49604579929B00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41824FC8D096C64EC5-8014
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Revision: 00002001
Coding: 01B8704E000000000000
VCID: 7BFEFD20FAFA6C9EDF-802E
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000194905008
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 20011600041500
Coding: 34A109B8250000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 63CEA5406A4AB45EF7-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0311
Revision: 14020001 Serial number: 00001249424202
Coding: 0105001540349FE2C1014083A0001800CF9DC3082F08020100000894E100120200400009090000
VCID: 70E4DA0CA3BC1FC67A-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 151116 H38 0080
Serial number: 151128193358
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 61226144
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 16 01 2016 00000718
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 4D190B08000000000001
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0080
Revision: -------- Serial number: 56261601401031
Coding: B83B14
ASAM Dataset: EV_EPHVA2CAU64X0000 001014
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 36682C14895871F660-8062
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Serial number: 00000000000000
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P10082051
Coding: 30333130313630323533554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B7E3D20B27AAC9E9F-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401A55AB6F0HU
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB401855AB699Q+
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB400U5558E61J$
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB400Q5558ESPCW
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405T3K3IE8HQI
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400A557QGG9ER
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OLI000CC
Coding: 0004FC
VCID: 3874222C8B4C878672-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H08 0010
Serial number: 17 11 2015 E0045264
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb
Part No SW: 4G8 920 987 HW: 4G8 920 987
Component: TDieGb Acc H11 0106
Revision: 08001098 Serial number: 658140116596009
Coding: 33860A000F552600010000
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
VCID: 76E8EC14C9D831F6A0-8022
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002111233
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS_001.rod
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 0364278803
Voltage stabilizer:
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 19011600041254
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3E783434A168B9B6B8-806A
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000181416385
Coding: 0078130000006001000001010101102030303232203232
VCID: 77F6E110C6D248FEBB-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820AUH9R
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H08 0060
Serial number: 0392857619
Coding: 040312
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_AU21.rod
VCID: 39722728B8469E8E8D-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H08 0060
Serial number: 0393010362
Coding: 040312
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F16015E01628002080013
VCID: 458A5BD8CCBEEA6EF9-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000003 Serial number: 0000568092
Coding: 101101010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106_AU57.rod
VCID: 3A703824BD40959684-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0392248694
Coding: 011B062280B90080C32008840C010E470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00017911223
Coding: 010000
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
Coding: 011F16015E01628002080002
VCID: 46885CD4F1B8E176F0-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001707817
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 31621F08603656CE35-8064
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FE02202A170200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 346C161C9F2463E65E-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021 D
Component: MU-H-LND-EU 051 0389
Serial number: A733A0GB004822
Coding: 017501010000000013111102000A00132F0006E7F17001009F
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1B3EDDA012BACC9E7F-804E
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FA HW: -----------
Component: ECE 2016 --- 0134
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY803UXN
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349PAJ00038
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F14004001628002080002
VCID: 499257E8E0A60E0E1D-801C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0138702
Coding: 0211000001000000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI.rod
VCID: 2F6619707602403E23-807A
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:* None
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: 6A160000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C5C0E7C47143B2606-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2756F1505EF2187EEB-8072
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000621401167
Coding: 04C239181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H14 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855) Labels:. 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H14 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3260100465306DD64C-8066
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 153311103
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
End-------------------------(Elapsed Time: 05:59)--------------------------
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
