Thread: Risk of pine needles entering engine....
  1. Risk of pine needles entering engine....
    Jun 2016
    Devon
    I've a 2003 A4 petrol and need to prevent pine needles getting into the engine through the vents just below the wipers with say some material or a sheet of plastic etc., however could this cause problems elsewhere ?
    Thanks for any suggestions....
    1982 Type 43 Audi 100 GL5E
    1984 Type 43 100 CS two tone
  2. Re: Risk of pine needles entering engine....
    Aberdeen
    63 Post(s)
    What about some kind of mesh attached underneath?
  3. Re: Risk of pine needles entering engine....
    Jun 2016
    Devon
    I've got an old lace net curtain I could make into a long "sausage" roll laying it across the vent for 2 or 3 days when I don't need the car, but wondering if this could cause knock on unventilated problems later on in the engine compartment as it could cause damp to build up say in the ECU ?
  4. Re: Risk of pine needles entering engine....
    1840 Post(s)
    A bi annual clean out is the best idea. We were doing a front wheel bearing on a 2005 this afternoon and it involves some violent thwacking and all up a sudden gallons of water poured onto the floor. We only cleaned the plenum out earlier this year. Also tomorrow our faithful 99 A4 is going to the breakers as blocked drains caused water to get into the passengers floor and damaged the side impact sensor, these are no longer available and impossible to find as cars with side air bags were rare pre 2000.
  1. Please Help Fir pine
    By L3g10n4rU in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-08-2017, 09:09 PM
  2. How To How to readjust the instrument needles after messing about with DIS LCD repair
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2016, 04:17 PM
  3. Please Help 2002 2.5 tdi A6 (c5 - B4 chassis) - water and oil temperature needles not moving
    By A6avantowner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-01-2015, 05:12 PM
  4. Resetting Needles.
    By benjie in forum VCDS - Help Requests
    Last Post: 10-07-2010, 07:17 PM
  5. lit needles and gauges
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 06:39 PM
