Thread: 2010 Polo control switch
  1. 2010 Polo control switch
    Jan 2016
    Winchester Hants
    29 Post(s)
    Hi all,
    The central control switch (heating/aircon) only functions on setting 4 (max).
    I can't think it's a fuse so perhaps a relay or solenoid somewhere.
    Any guidance much appreciated.
    thanks DJ
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  2. Re: 2010 Polo control switch
    Nov 2019
    Peterborough
    Quote Originally Posted by UMEL View Post
    Hi all,
    thanks DJ
    My dad's 02 polo (9n SDI) had the same issue (as did my mates Clio). Both were the heater resistor. In my dad's case, it was a fuse that had literally melted (had to wire in a New fuse). The Clio it was specifically the resistor in the matrix had failed
    Resistor has 4 pins/ settings iirc. 1 is low, 4 is full blast. If you only have blowers working on the full blast setting it's likely to be the fuse, if you get full blast on all 4 settings it's the resistor
    This being said the 2010 could be more complicated
  3. Re: 2010 Polo control switch
    Nov 2019
    Peterborough
    Quote Originally Posted by Chevmat08 View Post
    Meant to add if you have a blown fuse, and it keeps blowing them, the resistor is packing up and needs replacing. Again not a hard job on the 9n (behind the glovebox) but not sure on newer models
  4. Re: 2010 Polo control switch
    Jan 2016
    Winchester Hants
    29 Post(s)
    Thank you. I ordered a new sensor which has everything on it. Yes it's behind the glove box. A nice job for the weekend.
  5. Re: 2010 Polo control switch
    Jan 2016
    Winchester Hants
    29 Post(s)
    All fixed with the new sensor.
    The old boy,
  1. Question Cruice control malfunction on 1.6 TDI Golf MK6 2010
    By evenkg in forum Golf MK6 - 2009 - 2013
    Last Post: 28-04-2016, 08:34 PM
  2. Solved 2010 a6 avant 2.0 tdi s line a/c rad fan keeps running after switch off
    By mattsmith1985 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-01-2015, 05:25 PM
  3. Question can you retro fit cruise control to 2010 model sciroccos?
    By mad_kows2 in forum Scirocco - 2008-
    Last Post: 24-11-2010, 11:13 PM
  4. Question 2010 Ibiza - Retrofit cruise control?
    By malaroo978 in forum Ibiza - Cordoba
    Last Post: 27-01-2010, 03:07 PM
  5. 2010 A4 - 07-control head - can't access
    By TTQC180Canada in forum VCDS - Help Requests
    Last Post: 09-01-2010, 08:02 PM
