Thread: coil light flast and engine manangment sensors around the Exhaust help with output
Results 1 to 10 of 14
  1. coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    Hello ladies and gents.
    i own a 2009 vw golf tdi 1.6 im getting the above issues so i plugged it in to find the blow fault code so i replaced the Exhaust Gas Temp EGT Sensor (black plug)
    1 Fault Found:
    14355 - ROD - Unknown Error Code
    - 00 [167]
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 118354 km
    Date: 2019.10.24
    Time: 18:35:58
    Readiness: 1110 1000
    after replacing the sensor i now have these code below ? help!
    2 Faults Found:
    14356 - Exhaust Gas Temperature Sensor 4 Bank 1
    P246E 00 [032] - Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Date: 2000.00.00
    Time: 00:00:00
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 255 km/h
    Coolant temperature: 78 C
    Intake air temperature: 14 C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 12.536 V
    Unlearning counter according OBD: 40
    10107 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 00 [175] - Circuit Malfunction
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 118365 km
    Date: 2114.14.02
    Time: 22:06:52
    Engine speed: 1652.75 /min
    Vehicle speed: 65 km/h
    Coolant temperature: 76 C
    Intake air temperature: 16 C
    Voltage terminal 30: 14.118 V
    Exh.gas temp.sen 1-TEG_MES[0]: 19.98 C
    Exh.gas temp.sen 3-TEG_MES[1]: 192.04 C
    Exh.gas temp.sen 4-TEG_MES[2]: 188.10 C
    Outside air temperature-Ambient temperature: 6.00 C
    Time since engine start: 165 s
    Coolant temperature: 82 C
    Coolant temperature at radiator outlet: actual value-TCO_2: 29 C
  2. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    also a diagram with the banks and sensor numbers woul de useful if anyone can direct me to
  3. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    any help on this issue ladies and gents ??
  4. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    which sensor is Sensor 4 Bank 1 and Sensor 1 for Exhaust Temp Bank 1 can someone point them out for me ?
  5. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    35 Post(s)
    770 Post(s)
    What are you using as a diagnostic system?
    "I disapprove of what you say, but I will defend to the death your right to say it"
    Evelyn Beatrice Hall (1868-1956)
  6. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    thnaks for the response, VCDS version 19 is what im using.
  7. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    35 Post(s)
    770 Post(s)
    I think your interface is causing the problem with the code, which one do you have?
  8. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    Can you elaborate on interface
  9. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    35 Post(s)
    770 Post(s)
    Your VCDS interface, what is it? Before I upgraded to the HEX NET I was having similar unknown code issues.
  10. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    Meaning my Diagnostic system Is ross tech can you guide me plz this one-has really annoyed me to resolve
  1. Question Stop start malfunction, pre heat coil light, engine light
    By jcdub in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2016, 12:49 PM
  2. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  3. uh oh... coil light and engine management lit up
    By Phil K in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-10-2013, 10:50 PM
  4. 06 Polo TDi coil light and engine symbol light on
    By Grazuncle in forum Polo - Derby - Lupo - Fox
    Last Post: 01-09-2009, 04:19 PM
  5. Engine management & flashing coil light
    By JohnWithAGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 09:03 PM
