Thread: coil light flast and engine manangment sensors around the Exhaust help with output
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    1836 Post(s)
    Which VCDS interface do you have, the one you plug into the diagnostic socket? The curent top version is HEX-NET.
    VCDS | Product categories | Ross-Tech
  2. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    Yh hex-net
  3. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    Jan 2010
    walsall
    Anyone got a diagram from for sensor is in what bank with bank number numbered
  4. Re: coil light flast and engine manangment sensors around the Exhaust help with output
    1836 Post(s)
    You need to raise this with Ross Tech as to why it is an unknown code.
  1. Question Stop start malfunction, pre heat coil light, engine light
    By jcdub in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-12-2016, 12:49 PM
  2. Please Help Hesitation / power loss, flashing coil light, solid engine light and "Engine Failure Worshop!" warning
    By MHDxMK5BK in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-06-2014, 10:02 PM
  3. uh oh... coil light and engine management lit up
    By Phil K in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-10-2013, 10:50 PM
  4. 06 Polo TDi coil light and engine symbol light on
    By Grazuncle in forum Polo - Derby - Lupo - Fox
    Last Post: 01-09-2009, 04:19 PM
  5. Engine management & flashing coil light
    By JohnWithAGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 18-04-2008, 09:03 PM
