Thread: 140 Pdi Sport doors and coolant system hoses
  1. 140 Pdi Sport doors and coolant system hoses
    Nov 2019
    Aberdeen
    Hello
    The car doors won’t respond to open commands from my keyfob
    Not sure its a fob battery issue
    I’m having to open the front driver door with the manual key, setting off the
    alarm
    Also how much would I expect to pay for a set of coolant system hoses?
    Cheers in advance!
  2. Re: 140 Pdi Sport doors and coolant system hoses
    Jun 2006
    6 Post(s)
    Yes, probably the key fob battery, and we are getting through a battery every 4 months right now. If this doesn't work a far less likely but nevertheless relevant thing is to check that the wiring loom rubber gaiters between the door and pillars are not full of water. Peel the gaiter back to check for moisture ingress and when everything is dried out (Wd40 helps to dissipate moisture) be sure to use some lube to properly re-locate the gaiter into the pillar.
  3. Re: 140 Pdi Sport doors and coolant system hoses
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    The key I use day to day was very intermittent with remote blip. I haven't used the remote for years, and battery is probably now dead. Suits me as when it did work I used to find car unlocked, windows down, etc from where button was pressed while carrying keys in pocket. Remote works fine on the key my wife uses, and I think the circuitry, aerial, or code sync is messed up on mine.
    There is an option I set with VCDS to allow the car to be opened with a key without setting off the alarm.
  1. A3 Coolant and Coolant Hoses
    By DervyP in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-05-2019, 08:52 PM
  2. Polo 9n TDI Sport 6 line braided brake hoses
    By Tonksie93 in forum Brakes
    Last Post: 31-01-2016, 12:18 AM
  3. Please Help Air in coolant system after coolant change!
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-05-2013, 06:08 PM
  4. Important Oil in coolant system
    By crazycowell in forum Bora - 1998 - 2005
    Last Post: 14-05-2012, 10:33 PM
  5. Coolant hoses
    By golf96 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-12-2007, 09:16 PM
