Thread: Intermittent fault
  1. Intermittent fault
    Nov 2019
    goole uk
    Hi all im new to this forum but came across you while trying to find an answer to my problem. I have a 1.6 tdi bluemotion and the problem is the car has developed a fault which puts it into limp mode while running and flashes the rear lights and the high level brake light.Also the relay under the bonnet is buzzing constantly. If i turn it off the relay still buzzes and eventually the fans come on at full power. If you try to start it it's like the starter motor is faulty and just jerks the engine if i manage to start it the fault codes are as follows : P0687 P0090 P091 P0030 P0031 P0045 P0047 P2295 AND P2294 . The codes dont always clear on the first few attempts but when they do it runs and starts perfect i thought it had cured itself but the problem has come back . could it be something as simple as water in the fuse box or just a corroded connection somewhere. The battery is the correct type and is new i have done a drop test on the battery and it is fine also it is charging at around 14.4 volts. Any help would be much appreciated thanks Dave.
  2. Re: Intermittent fault
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. intermittent fault
    By Hawkwind1 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-11-2017, 10:51 AM
  2. Please Help EPB intermittent fault
    By lozp in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2016, 09:04 AM
  3. Question Intermittent fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2014, 05:54 PM
  4. Intermittent Fault
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2013, 11:35 AM
  5. Intermittent fault with ABS
    By davedru in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2009, 11:48 AM
