Thread: ESP light flashing limp mode
  1. ESP light flashing limp mode
    Jan 2009
    Birmingham
    35 Post(s)
    Had a problem with my esp light coming on when I’m driving for ages know soon as I switch engine off and back on drive a bit it would go off.
    But recently it’s been coming on and staying on only going off randomly after a few start and stops. Today it was flashing and I could feel brakes biting it was flashing really fast car was un drivable.
    Pressed the esp button to turn it off and made my way home.
    Vcds code that came up was
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    Had this code since the esp light first came up tried steering wheel angle calibration in Vcds but it’s ok for a few days then comes back Vcds does show angle of steering when straight at 0 degrees.
    Anyone have any idea what could be causing it? Or any pointers were I could start
  2. Re: ESP light flashing limp mode
    Aberdeen
    63 Post(s)
    01826 - Ross-Tech Wiki
    This is one of the best places to find possible solutions. Maybe change the sensor.
  3. Re: ESP light flashing limp mode
    Jan 2009
    Birmingham
    35 Post(s)
    Already checked that out when this happened about a year ago. Sensor a bit pricey and the age of the car plus this clean air zone coming to Birmingham next year i never replaced it as the car was running fine with the light on.
    i was thinking of checking the alternator out see if its causing the low voltage that might be causing the angle sensor to throw a fault in the summer it was fine as the weather has got colder it has started again and battery in new . Had the car for 11 years know and with all this clean air zone coming soon car will need to go just wanted it to last till then.
  4. Re: ESP light flashing limp mode
    Jan 2009
    Birmingham
    35 Post(s)
    Is there anyway of disabling esp using Vcds and keeps abs working?
  1. Question Coil light flashing, limp mode.
    By amjad175 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-01-2024, 12:45 PM
  2. Question Flashing glow plug light and limp mode
    By Snoopy2000 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 04-05-2019, 10:19 PM
  3. Question Glow plug light flashing and limp mode.
    By rozzer2005 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2019, 03:41 AM
  4. Question Glow-plug light flashing and car in limp mode
    By Pau1tech in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2017, 07:15 PM
  5. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
