Thread: Shark fin removal a6 c7 2013 saloon
  1. Shark fin removal a6 c7 2013 saloon
    Dec 2016
    Can anyone explain how I would go about removing the gps shark fin antenna? I have got 0 satellites issue and believe the antenna to be suspect. Would like to try replacing it with a proven working one but need to understand how to get mine out first. Does the headlining need to come out or am I able to access through the rear interior light?
    Much thanks
  2. Re: Shark fin removal a6 c7 2013 saloon
    Jul 2016
    Chestfield kent
    49 Post(s)
    Hi, not able to help in how to remove the Fin but around a year ago there was someone who had similar problem and resolved it by installing a receiver under the top of the dashboard. A search may find it it appeared to work very well. Hope this info may assist.
  3. Re: Shark fin removal a6 c7 2013 saloon
    Aug 2009
    cheshire
    61 Post(s)
    You dont need to drop the complere head liner; Rear c pillar trims need to come off, Removing rear grab handles help, Possibly brake light on back screen too but not 100% sure as i dont have a saloon. Once these have been removed the head liner can be pulled down from its rear clips allowing you to contort your nimble body enough so that you can slide your arms in the gap and removed the fakra cables and the T30 iirc torx bolt and clamp.
    Once this has been easily accomplished you can pull the aerial off the roof and inspect its poor design.
    Remove the miniture torx screws and you can remove the outer painted cover and swap it to your new working one.
    Reassembly is reversal if removal.
    Eazee peezee
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill plates,Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  4. Re: Shark fin removal a6 c7 2013 saloon
    Feb 2013
    Finland
    9 Post(s)
    Any help with this?
    Trying to find out why image is of poor quality, only a quarter of size of all previous images. Using same ipad and same screen capture results 25kb size, previous ones were around 100k...
  5. Re: Shark fin removal a6 c7 2013 saloon
    Dec 2016
    Unfortunately I canít make out what the text says 😩 thanks for trying tho
  6. Re: Shark fin removal a6 c7 2013 saloon
    Dec 2016
    Quote Originally Posted by morski View Post
    Eazee peezee
    Thanks for that, I was wondering if you were able to remove the painted cover or not. Going to give this a shot next week when my part arrives. Good replies though 👍🏻 Didnít fancy putting a receiver under the dash
  7. Re: Shark fin removal a6 c7 2013 saloon
    Feb 2013
    Finland
    9 Post(s)
    Painted cover can be replaced, if not damaged. Screws are some kind of self drilling and mates may be damaged.
  1. Audi A6 saloon roof bars wanted - 2013 year model
    By Bill Badger in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 24-04-2017, 10:58 AM
  2. 2013 Allroad rear bumper removal
    By A6AR in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-12-2016, 05:58 PM
  3. Saloon Headliner Removal
    By Norrington21 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-05-2014, 07:47 PM
  4. Trim removal help - A6 Saloon
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-04-2013, 06:06 PM
  5. 2013 Audi A6 Saloon
    By jonnymatrix in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 30-03-2013, 08:52 PM
