Thread: Please HELP boot lock broken and no rear wiper or washer
  1. Post Please HELP boot lock broken and no rear wiper or washer
    Wales
    Help, please , my 2011 B 7 estate tailgate lock mechanism has died , going out with a whirring noise when activated , I cant lock the boot and also noticed I have no rear wiper or washer , I can change the lock unit easily enough but is it linked to my failed wiper and washer ?
    There are no visible signs of water damage and the car is high mileage so lock failure is acceptable , I have activated the interior sensor to OFF hoping it does a little to help the alarm not going off , yet the car will sense an open tailgate so how can I counter act that issue until I can replace it Monday ?
    Grateful in advance for all helpful replies .
  2. Re: Please HELP boot lock broken and no rear wiper or washer
    Wales
    ok looks like im on my own
  3. Re: Please HELP boot lock broken and no rear wiper or washer
    Jan 2016
    Winchester Hants
    29 Post(s)
    My 10p's worth would be broken wiring loom where it passes through the boot hinge.
    I had my washer pipe repaired at this point.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  4. Re: Please HELP boot lock broken and no rear wiper or washer
    Wales
    Thanks for reply , I have bought a new lock mechanism as there are no visible damp patches on the headlining and the lock is dead , only the solenoid micro chip of the handle is engaging , after all the use it has had I'm betting its just a lock gone , it WILL also disable the rear wiper , VW technician said . I will try and fit it tmrw its simple swap over and you do not need to remove ALL the boot liner .
  5. Re: Please HELP boot lock broken and no rear wiper or washer
    Wales
    Ok all fixed , was a 5 minute replacement job , and everything is working as it should do. There was no visible signs of water leakage from the hose and I have put the failure down to excessive use and high mileage . VW main dealer part as I always use genuine parts £50. So relieved.
  1. No power in a4 avant boot lock and rear wiper
    By mrchimps in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-12-2015, 11:05 AM
  2. Replies: 7
    Last Post: 02-07-2014, 08:05 PM
  3. Broken Boot Lock
    By BrokenInSheff in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2010, 08:57 PM
  4. A3 Tdi 2005 boot lock / wiper problem
    By liverpoolphil in forum Audi A3 - Archive Topics
    Last Post: 11-12-2008, 11:10 AM
  5. How To Rear wiper and boot lock not workin
    By sumomus_01 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-07-2008, 02:02 PM
