Thread: Rear window lowering by itself
  1. Rear window lowering by itself
    Oct 2014
    Mansfield UK
    Hi guys
    I’ve got a 2014 A7 and on a couple of occasions lately the drivers side rear window has lowered by itself , done it a few times, usually only about 2 inches but then when I put it back up it’ll come down again either same or has gone to halfway, it’ll seem to do it a couple of times then stay up but doesn’t do it every time I use the car, anybody got any ideas? Checked to make sure nothing is stuck to the door seal and can’t see anything out of place
  2. Re: Rear window lowering by itself
    Nov 2019
    Cardiff, Wales
    18 Post(s)
    My 2009 A6 rear drivers side window used to get stuck occasionally when I was closing it which would cause it to think there was something trapped in the window and re-open a couple of inches.
    It never opened spontaneously though, it only happened when I had opened it and was then trying to close it again.
    1 1 0
  3. Re: Rear window lowering by itself
    Dec 2019
    southampton
    I had this on a Z4 coupe, turned out to be the window lift sensor, acting like something was blocking the window from closing then dropping the window a couple of inches, £50 sensor later and no more problems
  4. Re: Rear window lowering by itself
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Does it sound a bit strained when lifting? One of ours had a damaged / frayed wire cable which I think the sensors interpreted as a blockage on the actual window, so it misbehaved. As I went onto the M3 one day and closed windows for higher speed driving there was a big "crack" sound as part of the overloaded mechanism finally failed and the window promptly fell into the door. Bit breezy for 20 miles, but a window lifter repair kit sorted it out.
  1. Help with rear window. Please.
    By webofdoom in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-07-2018, 07:07 AM
  2. Please Help WANTED 1996 80 convertible rear light and rear plastic window
    By john-p- in forum 80 - 90
    Last Post: 28-01-2010, 06:20 PM
  3. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    By Ray P in forum Polo - Derby - Lupo - Fox
    Last Post: 14-12-2009, 10:15 AM
  4. Please Help 1995 POLO 1.3CL heated rear window and rear wiper, heated door miirrors problems
    Last Post: 14-12-2009, 12:01 AM
  5. Knocking rear suspension after lowering
    By Bighands89 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2008, 08:19 AM
